CB1100 2013: what is the original chain relation?
valkyrie_rider_imp
First service completed
Gentlefolks
I'm looking to replace the chain + sprockets in my 2013 CB1100 and wanted to double check what is the *original* relation before ordering the parts.
At Sprocket Center (HONDA CB1100 (13-19) JT Brand Steel Sprockets & 530 Chain Kit) they have a kit that supposedly includes everything needed.
I just wanted to double check if the relations are correct: 18 Front, 39 Rear, X-ring (1400cc rated).
Is the above equivalent to the OEM chain/sprocket that Honda ships on the 2013 CB1100?
Checked the OEM on line parts stores; you have the correct sprocket sizes (F-18 T, R-39 T). The chain rating should be fine. There should be 120 links (stock length).
Good luck
Good luck
For a direct replacement on a 2013 staying with the 18/39 ratio, use a 530 sealed chain, 110 links.
Pauley_imp said:
Good luck
Honda says it's 120 links, Pauley.
CHAIN, DRIVE (DID50ZVM-120ZB) (DAIDO)
40540-MBR-003
Honda
Randy B_imp said:
Pauley_imp said:
Good luck
40540-MBR-003
Honda
40540-MBR-003
Honda
New chains come with 120 links, you cut off 10 for the standard setup. I've gone through 2 sets of chains and 18/39 sprockets, always 110 links.
Pauley_imp said:
Randy B_imp said:
Pauley_imp said:
Good luck
40540-MBR-003
Honda
40540-MBR-003
Honda
40540-MBR-003
Honda
Ahhh... OK. Didn't know that.
