Cam Chain Tensioner/Lift ?
bflint
Been there
Has anyone replaced the cam chain tensioner and lift? I have the valve cover off to check clearances and was wondering what else would have to come off to replace the tensioner stuff.
What do you mean "lift"? The tensioner is on the outside of the engine and there are 2 chain guides, one in front and one at the rear that is operated by the tensioner.
Parts list:
1. SPROCKET, CAM (46T)
14321-MGC-000
$94.39
Qty: 2
2. CHAIN, CAM (154L) (BORG WARNER)
14401-MAZ-003
$105.75
Qty: 1
3. LIFTER, TENSIONER
14500-MAZ-000
$98.49
Qty: 1
4. TENSIONER, CAM CHAIN
14511-MAZ-300
$29.12
Qty: 1
5. BASE, CAM CHAIN TENSIONER
14520-MAZ-000
$59.57
Qty: 1
6. GUIDE B, CAM CHAIN
14546-MGC-000
$51.78
Qty: 1
7. GASKET, TENSIONER LIFTER
14560-MY5-851
$5.07
Qty: 1
8. GUIDE A, CAM CHAIN
14620-MAZ-000
$60.71
Qty: 1
9. BOLT, FLANGE (6X10) (NSHF)
90004-GHB-600
$3.10
Qty: 1
10. BOLT, FLANGE (6X25) (NSHF)
90004-GHB-670
$2.95
Qty: 2
11. BOLT, FLANGE KNOCK (7X10.5) (Honda Code 1824291)
90082-HA0-000
$2.95
Qty: 4
12. WASHER, SEALING (6MM)
90442-397-000
$2.95
Qty: 1
13. BOLT, FLANGE (6X14) (Honda Code 2410884)
95701-06014-00
$2.95
Qty: 2
Based on the current answers, I assume nobody has replace the cam chain tensioner lifter before.
dave said:
If it isn't broke, don't fix it.
Hey Dave ... the point is I don't know if its broke or not.  I just know I was hearing a loose tappet kinda of noise and the valve clearances are all perfect.  Also know that my previous 1991 Honda Nighthawk 750 needed a new cam chain tensioner at about 30k (in 2015) so that got me thinking about the possibility on my CB1100.   Replacing the tensioner lifter can be done anytime per my research, but the internal components (tensioner) require at least the valve cover to be off and maybe even the cams.
I don’t recall anybody ever having a problem with the tensioner lifter or having problems with it.
