Long story short, it is possible to install an exhaust cam into the intake side and reduce the harmonic buzz that I for one find annoying.
Thanks to PowerDubs for breaking trail in the cam experimentation. His "Cams Anyone" thread got me interested in the possibility of just using an exhaust cam for the intake side.
I looked at the total duration of the exhaust cam vs the intake cam and the difference was one degree on the "normal" lobes, 10 degrees less on the narrow cyl 1 and 2 lobes. Exhaust cam lift is about .004" less than intake, meaning to me less volume.
Before anyone gets too excited I will let you know I lost 5 hp, and as much torque. The loss was at peak hp so it is essentially 2 or three hp in the 3 to 4 thousand rpm range.
I dynoed it before and after with the nice folks at Freeman's Choppers in Chico.
That's me on the left and Nicole and Will. I won't bother posting the graphs, they are linear, the only difference is the "after" line is lower. Nobody wants to see a picture of the small fish you caught.
It also showed lean running, both before and after. I sent the computer off to Guhl's and I plan to have the original intake cam rebuilt so the lobes for 1 and 2 are the same as 3 and 4. I would welcome suggestions on a shop for that. Seems like PowerDubs had to wait for stinking ever for his, but since the work I require would be more straightforward I would hope for decent turnaround.
As far as running down the road, it is great. I have ridden it for 90 minutes a couple of times, once with no numbness in my hands and once with some tingle just starting. Normally I begin to have problems after 30 minutes or so.
The loss of power is not noticeable in real life, at least to me. I took it up to well over the speed limit a few times and it seemed to get there as quickly as it ever has. It doesn't have the growling howl it used to have on spirited acceleration, but it does have a very healthy exhaust note with the Yosh exhaust.
Other than the tingle, the thing that really bugged me about the staggered cam lobes was when I was reading some years ago about all the attention to detail the design got, then when they got this jewel built it didn't sound ferocious enough so they went back and designed in a noise.
Don't get me wrong, I love engine noise of all kinds, lawn mower to jet. Harleys too if they aren't just obnoxious. But when designers and builders weigh and measure everything to get a smooth mill and go back and change it to make it seem more authentic it bugs me.
The motors back in the day made that hot noise because it was a byproduct of the relatively unfettered machines of the day.
Anyway, I ramble.
Bottom line it is smoother. Acceleration is good, decel is good. It seems to be happier with any rpm you happen to be at. Maybe just me but seems smoother, with no harmonics on the way up in rpms.
Looking forward to getting my box back, and will start looking for a cam shop. I am sure I will end up with at least as much power as I started with, maybe more, but I am quite happy with the direction this is going.
Don't do what I did without expecting a loss of power. I was mainly interested in the rideability aspects.
If you want smoother, AND a hot rod, try PowerDubs grind with the stagger taken out.
Plus, he did some other things with the intake, etc.
Will let you know what happens.
Ben
Anyway, I ramble.
Ben
