NickyV_imp
First service completed
CB1100s that end up in the salvage yards usually have bad gauges, headlight, left engine cover - the same stuff. If Mr T's gauges read primarily in mph, that may be a good possibility. He should also be able to tell if it's for a pre-2014 model by the chrome trim ring and green face. The ABS version has a light below the tach needle.pekingduck_imp said:CB1100s that end up in the salvage yards usually have bad gauges, headlight, left engine cover - the same stuff. If Mr T's gauges read primarily in mph, that may be a good possibility. He should also be able to tell if it's for a pre-2014 model by the chrome trim ring and green face. The ABS version has a light below the tach needle.NickyV_imp said:The more I think about it, I may just bite the bullet and just order whole assembly from Partsfish as they have the lowest price. I feel that it would make my life easier and in the long run look the best since I haven't found any aftermarket speedo clusters that I really like. And not having to deal with any wiring is a plus. I appreciate all the support with this piece. Mr. T does have one for 950 plus shipping but is unsure if it's for 2013 or 2014, which means it could be for ABS or non as well. So it's still in the ball park price wise for a new assembly.
Good call on the salvage yard. I'm going to start looking into that to see if I can come up with anything nearby that can help.
One side part that I've been looking into is a black headlight trim ring. So just throwing it out there in case someone has found one.
If you can wait a day or two, I may be able to find the status of complete 2013 assemblies.
Ah. It's definitely a 2013 then. I didn't realize it changed that much for 2014, I thought it was the same color honestly. The one he has shows in km/h and I don't see the light below the tach needle.
Yeah, I can wait. Luckily I don't have anywhere to go right now. Almost done healing as well. And I'm going to order the left crankcase cover soon so I'll have to keep me busy when it arrives.
