Tyke57nz_imp
Running like a top
Thanks for that, appreciate the time and effort. Was getting a bit late for me last night, will go out with a different mindset and get it sorted.Tyke57nz_imp said:Thanks for that, appreciate the time and effort. Was getting a bit late for me last night, will go out with a different mindset and get it sorted.Pterodactyl_imp said:Tyke57nz_imp said:Fit the Staintune
G`day Pterodactyl, I see you have a Staintune fitted and wonder what clearance you have between the bottom shock absorber mounting bolt and the exhaust itself with no rider whilst on centre stand or sidestand. I had one sent through by my brother and the clearance seems minimal after comparing with the original unit which has a factory deformation in that area to allow a large clearance. Photo would be greatly appreciated.
Regards![]()
Side stand
Centrestand
Clearance is about 5mm, by eye. If you want precise will measure tomorrow. When the suspension is working there should not be a problem. I have applied a deal of force and can't put the muffler against the suspension. I think you would have to have a severe drop for contact to occur. Monitoring of the mounting bushes should be part of routine checks. On the other hand if you want to remove the lower shock mounting bolt then the Staintune would have to be removed. Not a big deal. There are a number of members on the forum with Staintunes and no reported problems. If I can be of any further help let me know.
Thanks for the info, was running a little late and probably should have left everything in the box till today. Will go out with a different mindset and it will all be sorted. Cheersxpacpal1x_imp said:If your Staintune lacks clearance near the shock, loosen all bolts (actually, completely remove rear bolt) and twist the entire muffler in order to reorient its positioning at the point where it attaches to the exhaust. You will eventually find a position which allows the rear of the Staintune to clear the shock by a nice margin and also seats the rear mount bolt and rear exhaust mount tab nicely with the rear factory mount point. I experienced the same issue and am OCD with respect to these things. I think what happens is that we're all happy to simply get the thing on at the first attempt...it is only later that we focus on the details (primarily how it hangs at the rear mount point). Again, I suggest you budget 15-20 minutes to the effort...twist it around and push it in and out as necessary at the point where the Staintune connects with the factory pipe, it is likely not bent or improperly manufactured...you just need to find the positioning which seats the Staintune correctly at both ends.
Done and dusted with a small amount of tweaking, sounds good but being a wimp I won`t go out at the moment as its persisting down.
) is the new way. Better?, well, mostly I guess, but not always.
