Broken shock bolts
woodsparrow_imp
First service completed
Was swapping shocks, torque wrench is apparently broken. Snapped both of the top bolts to mount the shocks in side the threads.
On a scale of 1 to sell the bike, how screwed am I?
I've been doing mechanical work for 15 years and haven't EVER snapped a bolt inside threads before. Because I'm careful. So I'm furious right now. Going to have to go to home depo and get some extractor and a tap/die set to fix the threads.
Also noticed that apparently the speedo housing is cracked, from the previous owner taking a spill.
I'm doing a lot of fixing his brokens.
Those little 6 mm bolts at the top of the shocks won't take much torque. From what I remember reading you are not the first to break one or more of those.
Anyone been able to use an extractor? Or am I looking at having to drill the entire hole out and tap it with a bigger one?
There is a thread on here about this. Like Ferret said, the torque is not much. About all the bolts do is keep the shock on. There is no real force on them. IIRC, the member drilled and extracted them. I'll have to search for it.
And here it is: Rear Shock Bolt Head Snapped
He used an extractor.
I've be bought and tried several extractors with mixed results. More success with larger bolts. 6 mm is on the small side but, if you can get a decent, well centered, hole drilled in it you may be okay. Best of luck!
Thanks Pop.
Looks like the included torque speqs for the shock were simply way higher than the 6 foot-pounds required. I new it wasn't holding anything on, but wanted to do it 'right' so...follow the torque spec.
Which works as long as you have the right torque spec.
I would 1st try a reverse drill bit. It should spin it out.
I have had to extract one of those. I used the cheap reverse drill bit type mentioned above. I just drilled a very small hole in the broken bolt for the extractor to bite into. It came out easy. Once the head is broken off there really is no tension holding it in.
I spent 2 hours working and fiddling with a reverse drill bit, extractor, type thing.
I finally said it could, expletive expletive expletive itself, and have drilled the entire thing out. I'll go back with a proper tap and die and resize the hole. Probably just use a #8 metric, since I don't think I'll be able to re-tap the #6 on both sides.
This is been a fairly crap week for me all around.
I'm feel'n your pain :exclamation:
More times than I care to remember I've run into a similar situation.
Since we've drilled already; might be able to go with an 8mm to 6mm threaded bushing.
Some other options in order of preference (IMHO)
- Time Sert. Not cheap, slick solution
- Heli-coil. A little cheaper, not as HD as the Time Sert
- Last resort, drill and weld in bushing, primer & paint.
Good luck.
Drill bit broke off in the hole while I was reaming it.
I'm pretty much done with this bike. Every time I touch it I find something else broken, rusted, needing replacement or repairs. And that's not even counting the stuff I break.
Even called up a dealership to see if they'd deal with this BS and they flat out said no, that I'd have to find a 'laser extraction' shop.
You are having a bum run woodsparrow.
I ended up limping it into a dealership, and the cost to repair what I broke, combined with the upcoming maintenance and new tires, was more than the trade in value of the bike. They had a CB500X on sale for 4k flat, and offered me 3k for the bike as-is.
I took that deal. Not incredibly proud but I've got a bike that I haven't broken.
