S. Wendelin said:
2017 model I was working on the taillight assembly I noticed that when I tightened the two screws holding the taillight unit into the bracket assembly that even when tight the red plastic assembly is free to wiggle in the bracket
Is this normal? I don’t know why I haven’t noticed it before I’m not missing any pieces as far as I know. I assembled using an exploded diagram to be sure I had all of the correct parts
Hello S. Wendelin...
No, it's not normal. Other forum members and I have had problems with this. I searched this forum and the other for a fix I came up with involving inserting rubber washers, but the link is dead.
Basically, I think what I found was that the threaded ends of the bolts go in too far, and then they don't grab anything. By inserting a rubber washer, the bolt's threads grab at the right spot and pull the unit tight, eliminating the rattle/wiggle.
A few photos from the thread that seems to no longer work:
Or it might have been this washer:
You might give it a try. Be gentle with the tightening down. Another member found that his unit where the bolts thread into was cracked if I rembember right.
Edit: since we're not supposed to upload copyright material (the exploded diagram), here's a beautiful artist's rendition of the bolts in question:
Don't laugh.
I believe those threads are too short to tighten down the assembly. Adding a washer gives the threads more bite in the right spot. That's my theory anyway. For me, the bolts with rubber washers pulled the assembly together and no rattle/wobble since (about 6-7 years ago).
