2017EX_imp
Been there
Because feet are particularly vulnerable, I saved my pennies and got a pair of Daytona CE rated armored boots. The only problem was that, as with most most boot and shifter combinations, I noticed that the steel end of the shifter and edge of the shifter rubber was rubbing against the inboard side of my boot. I caught it before the repeated rubbing abraded the leather. Most riders I have talked to are like me, in that we have a tendency to slide the foot under the shifter for up shifts, which catches the inboard side of the boot.
There are all kinds of "boot/shoe savers" out there that strap onto the boot. Most all that I have seen do not cover the inboard side of the boot, and are really not suited to walking around off the bike. Then there are shifter covers made of rubber, or a neoprene, both of which are the devil to install, and still rub the inboard side of the boot.
I started looking for a low to no friction cover for the shifter that would allow the side of the boot to slide under the shifter without abrading the boot leather, and couldn't find any such thing. I had a new pair of stretch cotton jersey work gloves found at Harbor Freight for $4 for 5 pairs. I cut the thumb off one of the gloves and stretched it over and onto the shifter. The raw end I rolled over underneath and inside itself, then put a small zip tie around it, between where the shifter rubber ended, and the shifter arm. Positioned the zip tie connection at 2 o'clock to avoid contact with my boot.
So far it works perfectly, but time will tell. I think I will cut the zip tie and pull it off for washing the bike and reinstall when the bike is dry. I am also thinking if this works long term, I may find a cheap pair of black unlined leather gloves and use the thumb to replace the cotton jersey. The pictures show the idea probably better than I can explain it.
