Big Feet
Wagonpeddler_imp
Running like a top
I have an issue trying to get my size 12W shoe under the shift lever. The lever is short and angled downward somewhat. I typically perform upshifts with the side of my shoe pressed against the edge of the rubber boot on the lever. Is the shift lever adjustable? Is there a longer aftermarket lever available? Moving it up 1/2" would make a huge difference. Will be removing the lever soon anyway to be able to bleed clutch fluid.
Thanks.
It is adjustable for up or down. Not a super lot but some. I forget how much and would have to look in the service manual to see if the amount is listed. I did mine when I bought it in '13 and haven't messed with it since.
Thanks.
I have size 14's and had that problem as well on my 2014 ,yes the shifter linkage is adjustable and makes a world of difference
Thanks.
Yikes! - size 14.
A big welcome to the Forum 340duster!
Welcome 340duster!!
Pics of big feet or it didn’t happen :P
peterbaron_imp said:
Lord Popgun_imp said:
Welcome 340duster!!
I second that :)
I second that :)
Ok, just go to wikifeet and get it over with. :excited::P:banana:
I replaced the original rubber thing with one from the earlier model Honda's. Maybe they will help a little?
Sent from my Pixel 6 using Tapatalk
