Ulvetanna_imp said:
Hawkeye_imp said:
Ulvetanna_imp said:
I installed a BackOff module. All the wires can be accessed directly under the document compartment along the left frame rail. I flat-mounted the module on the forward part of the rear fender, using the sticky tape or whatever was provided but also secured it with a silicone band I had laying around from a GPS mount for a bicycle. I guess I need to go get you an image...
[attachment=5525]
Ulvetanna,
Many thanks for your much appreciated details and photo; they are very helpful!
May I ask if you soldered the wires, or did you use another type of connection?
Thanks again!
Ulvetanna,
Thanks again! As I recall, I used the standard crimp-type connectors on all connections. I like this module, I really do feel it helps get a bit more attention. I ride in a lot of traffic so it seems to be a good modification.
Ulvetanna,
Ulvetanna,
Thanks for your response.
I researched a number of flashing brake light devices; many claimed to have the most advanced and/or best flashing patterns, but the BackOFF appealed to me the most.
Thanks again for your help!
