b12thechank_imp
First service completed
First post, hello everyone just a update from a post I saw like 1 or 2 years ago so not sure if it is still relevant or if anyone already did this, couldn't find a post that did. First time seeing these forums was when I was looking for saddle bags and got pointed out to a thread started by tomas (Samurider Paniers-review + pictures), which btw thank you very much tomas went with the accessories because I thought the end result pics on your post were the $h!7. Pretty much got the same setup as far as windscreen and panniers, no regrets til recently at 12k miles feeling like I needed more trunk space on my daily commute. So to the point, someone asked if theres any way to get a rear rack connected with the Asahi Panniers since the description on them states can't use with rear rack, assumed it only meant the Honda OEM, with an extra pair of 65mm m8x1.25 screws, same length and size as the rear set of screws that come with the panniers, to replace the front set the Givi SR1118 for the 2013-2014 cb's fit perfectly & handles my full 205lb bearing weight at the end of the rack, wouldn't test that on the panniers though. the rack adds like an extra 1/5th of an inch distance for the panniers on both sides, which I felt was needed but at the same time didn't feel or look like its any wider. Just if anyone was interested, and a long hello
. Sorry about the lighting, only time I get to work on it is past 9pm. Just need to get a top case to match now
