It will fit as Retsel said. A few HAVE done it already. Just be aware that the fuel gauge reading will not be correct. Close, but not as good as you are used to now.
I gotcha. Do you think it would read over or under the actual fuel content? Also I thought I read on here about a way to recalibrate the fuel gauge awhile ago. Do you know anything about that?
I think it read low when it wasn’t. The only way to recalibrate is to bend the float arm. I’ll have to search around to find the thread.
Check out this post and the one following: I think Its Done
And this one by me: 14 STD W/ 17 White Tank There is another hose you have to add to and route down to under the bike. Just read post 16 about that hose.
You can search on 2017 tank, select posts (instead of threads) and a lot of posts come up. I’m not reading them all.
Ben, if you didn’t, look at the bike in the first post of the thread: I think Its Done
Its a ‘14, but the ‘13 and ‘14 tanks fit each other. Pretty much all the models do. Maybe the dlx is tad different. I think it fits, just tight against the seat, but I’d have to search again.
"13 and "14 tank models are swappable for sure = I did mine (Canadian)
You only have to transfer fuel pump assy (both have an oval shape housing), cuz '13 has a flat 3 pin connector versus '14 - 4 pin square. Fuel reading are fine, and bottom/reserve = perfect
As many other and Popgun mentioned, Takashi will have a final say about yellow tank.
Good luck, nice colour chosen:clap:
I can certainly understand wanting a larger fuel capacity and a cool seamless tank. if it's the color you're after, get the stock tank painted. Then you get to keep the cool wing badge and the ability to use a magnetic tank bag
