ABS exciter ring ?
CBwannaB_imp said:
Do all CB's have an exciter ring on the rear wheel or only the ABS equipped bikes?
ALL do = it also serves function as RWSS, regardless of an ABS system
If an exciter ring is what I think, they all have it. It’s used by the speed sensor.
You and Peter both get points.
It is also known as a reluctor in the automotive industry.
It triggers the adjacent sensor.
If I were set up to post photos, I could show them in a vibratory feeder bowl going to a robot for vision inspection at the stamping house. Think our customer's customer was Toyota. Application was each wheel.
Beware if the bike is a 2013 std, or a 2014 std, even though they have that ring on the rear, they do not have ABS.
2013 ABS models, 2014 Deluxe models and I believe 2017 EX models have a ring on both wheels and do have ABS.
if it doesn't have one of those rings on BOTH wheels, it DOES NOT have ABS regardless of what a salesman tells you.
Do you want me to post them for you?
Thanks to everyone for that information. I was unsure about that
Thank you, but may not really be that informative, since these are points on a wheel and the CB uses the window type. But, if you want, PM me your email and you can decide.
If you're happy, it's fine. Unless, of course, there's a call for them.
