Pterodactyl_imp
Road warrior
Mate I don't think I have made myself clear. In a steady state condition, that is the motorcycle is at a constant speed, say 30mph, the weight of the bike is distributed approximately 50/50 between front and rear wheel. Lets say you now want to initiate an emergency stop using the rear brake only on a standard road surface. Don't ask me why you'd do that, except, maybe, to see how effective the rear brake is. There is good friction between rear rubber and road surface and, assuming the bike is kept tracking straight, little likelihood of the rear wheel locking. The bike eventually comes to a stop. The rider's perception is that the rear brake is not effective. Guess what? That's correct. Why?The ferret_imp said:Great ride! .... As usual
Talking about braking..Randy I believe there is some residual transfer of weight when stopping with the rear brake only (hard to deny physics) but nothing like the transfer of weight on the front end when the front brakes are applied. Which are why larger diameter, multi piston caliper dual discs are on the front, and smaller diameter single disc with fewer piston calipers are on the rear.
Ptero... Yes there is a big difference between " testing" and full emergency panic braking. Not disputing Keith Code's numbers, as I have heard other numbers as well, but whether the numbers are 90/10 80/20 70/30 whatever the numbers are, it is important that the rear brakes function properly. When guys tell me they never use their back brakes, only the front, I just have to wonder why they would give up that extra measure of braking voluntarily. Why would you give up even 10% (using Codes figure) of the braking power the rear brake provides? If rear brakes were not vitally important, why would MotoGP bikes have them? They could save weight and complexity by eliminating a disc, a carrier, a caliper, a hose, a master cylinder and fluid, yet as powerful as the huge front brakes on MotoGP bikes are, they still have rear brakes and I'm guessing when they hurtle down a front straight to a tight hairpin curve, the MotoGP riders use them. Braking hard with the front unloads the weight on the rear making the rear brake less efficient, sometimes to the point of lifting the rear wheel off the ground, but in a non emergency situation ( heck even in an emergency situation) using BOTH brakes is the most efficient way to stop, and both should be strong.
Strong brakes are more important to me than having 100 horsepower, or a motorcycle that will run over 100 mph. I rarely (virtually never) ride that fast, but I often have to brake hard. Several times in the last few days, once when I came around a corner only to find stopped cars in my lane due to a stopped school bus, and another when an old man obviously didn't see me and pulled out in front of me. I rely on my brakes saving my life.
I don't want my rear brake to lock up. I dont want my front brakes to lock up either. A skidding motorcycle is an out of control motorcycle (which is why ABS is such a good safety feature) but I want the strongest front and rear brake I can get prior to them locking up, or prior to the abs kicking in, whichever comes first.
The easiest remedy for brakes that are not as efficient as they should be are multi fold. # 1 bleed the system to eliminate any air in the system. #2 deglaze the brake pads # 3 clean the disc #4 replace the stock pads with a pad with more bite #5 replace rubber lines with stainless lines after that its replace disc, replace caliper, try better brake fluid, depending on how much braking power you desire.
Well, the brakes are a linked system on any bike that has front and rear brakes. "What?", you say. No I'm not mad, they are linked either by the rider applying both front and rear, or by a mechanically linked system, and are meant to be used as such, a system. Not one at a time or one only. And I'm not talking here about trail braking at speed or rear brake only application during slow speed manoeuvring. I'm talking about bringing the bike to a stop as expeditiously as possible.
So in the example above both brakes are applied, as they should be, both front and rear, and, assuming a manual system, as firmly as possible. What happens? There is a rapid and dramatic C of G change due to deceleration and the riders weight now transferring from the pegs to the bars. This now results in, using Code's numbers, a front/rear weight distribution of up to 90/10. 70/30 would do as well because the principle is the same. The rear wheel now has a greatly reduced responsibility in the endeavour of preventing you, and your beloved CB, face planting that U-turning soccer Mum (no offence meant ladies, soccer Dad would do). In fact at maximum pedal effort the rear wheel may, no, it will, lock up. Do you need any more braking than that? No. In fact it's too much. That's why ABS compensates for a heavy foot and prevents lock up.
If you don't believe that reduced weight on the wheel means the brake needs less effort to lock the wheel then consider this. Put your foot on the ground with all your weight on it. Now get your dearly beloved to attempt to kick it out from beneath you. Too hard to do? Yes. Now take most, say 90 per cent, or 70 if you like, weight off that foot and get dearly beloved to try again. Too easy. Without support you fall on your backside. The reason I've given that illuminating glimpse of the obvious is to avoid discussion regarding coefficients of friction (and traction) (and contact patches) clouding the issue as it has in another thread.
So the rear brake, to be effective, does not need the massive stopping power of the front brake. In fact, if it had that power the risk of lock up through heavy footed buggers like me misapplying them is a real factor. In the case of the CB in a full on emergency stop then max effort will produce a lock up. I know, I've done it. Need any more rear brake than that? No, less actually. You are not giving up anything. In summary, and to paraphrase Goldilocks, the CB brakes are "Just right".
Cheers, and now it's my turn for a ride.
Ferret, just read your previous, posted while I was typing. The brakes are nicely balanced, that's why you never noticed. This discussion has produced brake hypochondria. You know, like oil virus. Worse than Ebola.
