Sep 15, 2024 #1 D Darrell_imp First service completed Thread starter I’m installing a heel/toe shifter (because I have left drop foot). To make it fit I need to cut off this metal loop. Does anyone know what its purpose is?
Sep 15, 2024 #2 the Ferret Road warrior So you can kick the side stand out otherwise its up tight against the bottom of the bike
Sep 15, 2024 #3 peterbaron Road warrior I use it to engage bike’s side stand without looking at it while on my bike, don’t think there’s any other purpose..?
Sep 15, 2024 #5 Karidis First service completed Can you heat it and bend it back (down) to gain clearance?
Sep 15, 2024 #6 D Darrell_imp First service completed Thread starter The ferret_imp said: So you can kick the side stand out otherwise its up tight against the bottom of the bike Click to expand... Karidis_imp said: Can you heat it and bend it back (down) to gain clearance? Click to expand... Good idea, I’ll give that a try before I cut it off
Sep 15, 2024 #7 Karidis First service completed I think if you can line it up to sit underneath the shifter pivot you might get it to work.
Sep 15, 2024 #8 D Darrell_imp First service completed Thread starter The ferret_imp said: So you can kick the side stand out otherwise its up tight against the bottom of the bike Click to expand... Thumbs up emoji. Karidis_imp said: I think if you can line it up to sit underneath the shifter pivot you might get it to work. Click to expand...
