2013 cb1100 chain appears to be rubbing against center stand??
Kirbythefat_imp
New to the forum
Hello bros.
I bought this 2013 cb1100 that appears to have the center stand rubbing and pulling a portion of the chain up. I’m wondering if this is normal.. the bike has a Delkevic exhaust. Does anyone else have a picture of their own 2013 cb1100? Does it look like this at all?
The Delkevic pipe should have a "stop" for the center stand. Mine does but when I first installed it I had the chain rub. The pipe probably needs to be turned and tightened down properly.
Sent from my Pixel 6 using Tapatalk
Kirbythefat_imp said:
Hello bros.
I had the same problem with my bike. The bike came with the Delkevic exhaust and the bump stop on the exhaust spins too easily. It then lets the center stand hit the chain. I tried everything from clamps to a new insert directly from Delkevic. I finally had to drill a hole where the two pieces come together and put a bolt and nut there to stop the spinning, it was a pain in the butt but that fixed the problem.
I had the same issue TODAY with a noise and found the same center stand rubbing the chain issue. Fixed now and quiet as a mouse. Glad it was an easy fix. It made noise like something that was going to cost me money and it is only the first week I have owned the bike. Whew!
