Kaoko throttle lock
twiin640_imp Offline
Threads: 3
Kaoko throttle lock
I've been doing research on cruise controls and throttle locks for my CB. I've pretty much settled on one from Kaoko. Has anyone installed one of these on a 2013 CB and which part number did you get?
On the Kaoko website, the part number for our CB's is listed as HND30-19. In all my checking it appears that the correct part number should be HND100. I found others who have verified that HDN30-19 doesn't fit. Does anyone have any different info? I have found a company that has the HND100 in stock and want to make sure I purchase the correct one.
As always, thanks in advance for any info. Big Grin
02-24-2015, 08:08 PM
Likes Given: 1,015
RE: Kaoko throttle lock
Can you buy it on the basis that, if it isn't right, they take it back and get you the correct model?
02-24-2015, 08:22 PM
Threads: 698
Likes Given: 792
The only reference I can find to throttle locks/cruise conttrol in the archives is an Omni cruise control
I would suggest emailing customer service at Kaoko for correct info, then updating this thread so others will know.
02-24-2015, 09:11 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
This thread is interesting. Read the last post too. You may want to call Kaoko
http://cb1100forum.com/forum/showthread....ight=Kaoko
02-24-2015, 10:41 PM
redbirds_imp Offline
Threads: 186
I just canceled an order for a Kaoko through Twisted Throttle after reviewing the cited post. I explained the problem to the guy at Twisted Throttle and he was unaware of it. I really need a throttle lock as my arthritis is causing pain in the right hand on longer rides.
02-24-2015, 10:54 PM
Lord Popgun Offline
Virginia
Likes Given: 142
The BrakeAway is an awesome control. But it is pricey and like Ridem posted in a thread, is fiddly to install/adjust. Not hard, just kind of a pain. But it works good. I have one on the ST and just put one on my CB last weekend.
If you get one, be aware that the intstructions have a couple of steps that are not really correct and will result in it not working correctly.
Also, they say it does not work with heated grips due to interference with the wire for the heated grip.
And for ferret, yes I put the heated grips on the ST and I made the BrakeAway work. Don't tell BrakeAway Wink
02-24-2015, 11:51 PM
Threads: 698
Likes Given: 792
also noted where flynrider uses a Go-Cruise cruise control unit
02-25-2015, 12:34 AM
AllenM_imp Offline
Threads: 4
My friend uses the throttle crampbuster $10.95 made in Rogue River, OR about 30 minutes from where I live. Worth a try for the price!
http://www.crampbuster.com/
02-25-2015, 01:15 AM
Lord Popgun Offline
Virginia
Likes Given: 142
I have those AND the BrakeAway. Crampbusters, or ones like it are great. Even had one on a scooter.
02-25-2015, 01:21 AM
Threads: 3
I found info that shows the 2013 CB500F has the exact same handlebar id and internal weights as the CB1100. The kaoko part# for the CB500F is HND100. So the HND100 should work just fine on the 1100. I started this thread in hopes of finding someone who has actually installed the HND100 kaoko on the 1100 as a last measure before I go online to Twisted Throttle and buy it.
02-25-2015, 02:12 AM
  Honda U Lock guitardo_imp 12 948 04-09-2026, 09:36 AM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 329 01-04-2026, 01:26 PM
  Phone or Sat Nav? What mount ? Quad lock or...... Davidjill_imp 18 1,402 07-28-2024, 08:49 AM
Last Post: SportsterDoc
  Anyone using the Kaoko throttle control? milkmaster_imp 50 3,347 07-12-2023, 06:45 AM
Last Post: milkmaster_imp
   Quad lock stem mount Dunn2020_imp 5 557 06-07-2023, 12:36 AM
  CB1100 Lock Lord Popgun 100 7,120 12-24-2022, 11:15 AM
Last Post: olafurarason_imp
  Installation of a Quad Lock Wireless Charger [No Cut Mod] LayerCake_imp 5 663 06-17-2022, 07:44 AM
Last Post: LayerCake_imp
  U-Lock Rubber Band LakeWylieJoe_imp 39 2,498 05-02-2021, 04:00 AM
Last Post: LakeWylieJoe_imp
  QUAD LOCK IPHONE SYSTEM Alfgaxatico_imp 33 1,895 01-25-2021, 08:39 AM
  KAOKO cruize control ozigoo 6 542 05-27-2020, 01:14 PM
Last Post: 17-CB-002
