Power Commander V sale
HikerToo_imp Offline
Threads: 114
$250 at Motomummy, that is where I bought mine before reselling to get the ECU flash.
https://www.motomummy.com/dynojet-powerc...-cruisers/
03-14-2015, 07:34 AM
jsinher3_imp Offline
Threads: 10
RE: Power Commander V sale
can i ask you why you decided to go with the reflash instead? im debating between two right now..
03-15-2015, 03:36 AM
Olyrider Offline
PNW
Threads: 23
(03-15-2015, 03:36 AM)jsinher3_imp Wrote: can i ask you why you decided to go with the reflash instead? im debating between two right now..
+1
03-15-2015, 05:38 AM
Threads: 114
flash does air/fuel mixture like the PCV( actually, that's all the PCV does)
flash does timing
flash removed upper speed limits and raises RPM cutoff
flash is more permanent though and can not just be removed like PCV
Plus I live near Don at Guhls so dropped my CB off to him to be put on his Dyno and tweaked.
I'm sure if you have a 13 CB he will use what he learned from mine on future ECU's sent to him, most likely a 14 will use mine as a base too, until or if someone ever drops a 14 off to him for Dyno work.
03-15-2015, 06:43 AM
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 902 05-15-2022, 11:42 AM
  Usb-c cable direct to battery or switched power capz65_imp 5 580 04-16-2022, 02:26 PM
  Power Distribution Module (PDM) - Europe/UK Tev62 5 547 11-16-2021, 07:49 PM
Last Post: j3gq_imp
  Power Commander 5 and Dyno Tune iamheero_imp 7 620 07-18-2020, 04:14 AM
  Power Port for 2014 CB1100A (Deluxe) MWV1500_imp 5 508 12-06-2019, 09:00 AM
  Power commander. kmoney_imp 19 1,680 08-19-2019, 09:38 AM
Last Post: Ben70_imp
  2013 cb1100 power commander help 2000zx750r_imp 4 475 06-16-2019, 05:43 PM
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,379 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  JB-Power Magtan JB4 Magnesium wheels lola_imp 37 2,301 07-03-2018, 10:05 PM
Last Post: FLYTYM_imp
  anyone tried power commander with the auto tune sensor? scott will_imp 9 784 04-28-2018, 03:46 AM
