led plate frame
DJS_imp Offline
Threads: 18
led plate frame
interested in mounting a LED plate frame similar to this one.
http://www.motorcyclecloseouts.com/extra...AnM68P8HAQ
[Image: 850d2e89d6af63eeea4788b2c2b12d21.php?id=253971]
install instructions..
[Image: 8a96d0345e66c9ff7668ea1192850f93.php?id=253977]
i am wondering about the installation regarding the wiring.
it is a 6 wire hookup (left turn, right turn, brake, running, plate and ground)
what i am wondering is where all connections can be made.
are the running , brake and plate able to be connected to the wires in the brake light itself?
where best to tap the turn signals? how do the wires get routed from the plate to the hookup location?
is there something the ground could be attached to or should it be attached to the ground of one of the other lights?
TIA
04-21-2015, 03:26 AM
holy666diver_imp Offline
Threads: 37
RE: led plate frame
I had this same plate on my last bike. I found it easiest to just splice into the existing wires in the back because the length on the wires will not reach the box.
I also had issues with that plate trapping moisture in the LED clear case over the lights
04-21-2015, 05:48 AM
DJS_imp Offline
Threads: 18
RE: led plate frame
(04-21-2015, 05:48 AM)holy666diver_imp Wrote: I had this same plate on my last bike. I found it easiest to just splice into the existing wires in the back because the length on the wires will not reach the box.
i am not getting that exact one, just one similar.
when you say splice the wires in the back, is that the wires inside the brake housing?
i have not removed the brake light to see what the situation is like in there regarding wires and extra space.
04-21-2015, 06:18 AM
Threads: 37
RE: led plate frame
Yes both the signals and brake wires should be tucked up in the brake box in the back I just cut the wires and spliced the signals and brake lines together. Either that or find a way to route them.
I'm not a mechanic though so it may not have been the best way pf installing it.
04-21-2015, 07:28 AM
  axle / frame sliders dlm1100_imp 9 984 06-02-2023, 10:41 AM
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,673 07-23-2022, 06:02 PM
Last Post: rich_imp
  Frame sliders/engine guards Cqrlm911_imp 81 5,082 11-10-2021, 06:46 AM
  License Plate/Tail Light Bracket eddi0_imp 0 246 03-08-2021, 09:42 AM
Last Post: eddi0_imp
  Where to get a seat pan/plate? Sodbuster_imp 4 553 10-26-2020, 10:53 PM
Last Post: Sodbuster_imp
  Honda "Power of Dreams" License plate frames pekingduck 15 1,254 06-01-2020, 11:24 AM
Last Post: TXBikerGuy
  Getting rid of the ugly license plate bracket. ChipBeck_imp 93 6,509 05-21-2020, 02:02 AM
  Side mount plate number CB1100RS Moe_rider_imp 0 293 11-03-2019, 07:54 PM
Last Post: Moe_rider_imp
  Skid plate justinlself_imp 10 749 12-01-2016, 12:16 AM
Last Post: Ulvetanna_imp
  Headlight number plate combo Hondahawkrider_imp 5 484 09-01-2016, 02:11 AM
Last Post: redbirds_imp
