Aux power
Southwend Offline
Von Zipper
Clarksville Virginia
Threads: 29
Likes Received: 8 in 4 posts
Aux power
I could use a recomendation on where to find an aux power source for my gps I am highly directionaly challenged and would love to have one mounted somehow on the bike. Some velcro on and off configuration. Maybe an ear plug.
05-18-2015, 09:08 AM
vfrpaul98_imp Offline
Threads: 15
RE: Aux power
(05-18-2015, 09:08 AM)southwend_imp Wrote: I could use a recomendation on where to find an aux power source for my gps I am highly directionaly challenged and would love to have one mounted somehow on the bike. Some velcro on and off configuration. Maybe an ear plug.
located inside your headlight shell is an unused Red two pin wire connector with the wire colors Black with Brown tracer = (12 volt switched hot key on)fed from the 10 AMP fuse (D) in the main fuse box. the green wire in the same connector is common ground.
Paul
05-18-2015, 09:52 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Aux power
What Paul said. Plus there is another accessory connector by the battery, left side in a plastic protector with some other connectors. Its red too.
Ram ball mounts are nice. And easy. The one I use replaces one of the handlebar clamp screws. There are others like handlebar clamp mount, etc. Ram has a lot of options.
05-18-2015, 10:44 AM
Southwend Offline
Von Zipper
Threads: 29
RE: Aux power
I can do many things well, messing with electricity is not one of them. So one wire is black with brown stripes and the other is green-ground. This is a switched circuit. This would be an adequate source of power fo a cigarette lighter style auxillary plug? Is there a bike friendly mounting system for the aux plug? I prefer switched to unswitched for all the obvious (dead battery) reasons. I have a Parabellum Scout Fairing on order, I bet I could have a tidy application using the fairing as a mounting surface, with perhaps a disconnect for when the fairing is removed.
05-19-2015, 01:02 PM
Lord Popgun Offline
Virginia
Likes Given: 136
RE: Aux power
Currently there are no known accessories for either of the accessory connectors. If you want to use them you have to cut the wires or de-pin the connector, or chase down a mate for it. They are Hitachi connectors and somewhere on this site is a link to a source.
I THINK they are 10amp fused, but I'll have to check. The wires look a mite small to me for 10 amps.
You could just run some(fused) wires back to the battery for a Powerlet outlet or cigarette style outlet.
05-20-2015, 03:01 AM
Southwend Offline
Von Zipper
Threads: 29
RE: Aux power
Probably the simplest solution is the wire to the battery. Plus with a lighter style plug in, the circuit is only closed when something is in it.
Popgun your "fork in the road" reminds me of a favorite Groucho Marx quote,"when choosing between two evils I always pick the one I haven't tried before."
I bet I can find battery connectable cigarettelighters with inline fuses at an auto parts store.
05-20-2015, 03:36 AM
Likes Given: 82
RE: Aux power
If you are going direct to the battery, there are a couple of accessories that may work for you that use the pigtail for your battery charger. http://www.batterytender.com/Accessories/
05-20-2015, 04:08 AM
veech_imp Offline
Threads: 3
RE: Aux power
If you end up wanting more than one accessory, one of these options may be better. Just wire to battery and wire accessories directly to them. One is straight wired, the other is programmable:
http://www.revzilla.com/motorcycle/rivco...fuse-block
http://www.revzilla.com/motorcycle/power...-fuseblock
http://www.revzilla.com/motorcycle/denal...ess-module
http://www.revzilla.com/motorcycle/rowe-...ion-module
05-20-2015, 04:51 AM
ClassicVW_imp Offline
Threads: 6
RE: Aux power
Just last night I finished installing a fuzeblock on my CB and connected Denali driving lights, my GPS power cord, and the battery tender leads to it. Put it and all the bundled up excess wires in the glove box above the battery. Its quite stuffed with wires, but there was not any depth elsewhere like under the seat to hide it, which is where I usually put it on my other bikes.
There was no need to install a cigarette lighter type plug since I had the fuzeblock. If anyone wants to put a cigarette type plug on their handlebars, there are ones sold on ebay for around $12-$15.
05-20-2015, 07:28 AM
treytexag_imp Offline
Threads: 5
RE: Aux power
(05-20-2015, 07:28 AM)ClassicVW_imp Wrote: Just last night I finished installing a fuzeblock on my CB and connected Denali driving lights, my GPS power cord, and the battery tender leads to it. Put it and all the bundled up excess wires in the glove box above the battery. Its quite stuffed with wires, but there was not any depth elsewhere like under the seat to hide it, which is where I usually put it on my other bikes.
Classic, can I see how your Denali install came out? Love to see some pics sir.
Thanks.
05-20-2015, 07:41 AM
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 743 05-15-2022, 11:42 AM
  Usb-c cable direct to battery or switched power capz65_imp 5 491 04-16-2022, 02:26 PM
  Power Distribution Module (PDM) - Europe/UK Tev62 5 486 11-16-2021, 07:49 PM
Last Post: j3gq_imp
  Power Commander 5 and Dyno Tune iamheero_imp 7 544 07-18-2020, 04:14 AM
  Power Port for 2014 CB1100A (Deluxe) MWV1500_imp 5 440 12-06-2019, 09:00 AM
  Power commander. kmoney_imp 19 1,457 08-19-2019, 09:38 AM
Last Post: Ben70_imp
  2013 cb1100 power commander help 2000zx750r_imp 4 419 06-16-2019, 05:43 PM
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,117 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  JB-Power Magtan JB4 Magnesium wheels lola_imp 37 1,825 07-03-2018, 10:05 PM
Last Post: FLYTYM_imp
  anyone tried power commander with the auto tune sensor? scott will_imp 9 706 04-28-2018, 03:46 AM
