K&N air filter?
Papa Weeley_imp Offline
Threads: 44
K&N air filter?
Anyone using the K&N on their bike? If so, did you notice any discernible difference with it? I've put these on just about every vehicle I've owned for years, so I'll probably be doing it anyway, just curious if you could feel any increase in airflow and/or power.
05-22-2015, 02:44 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: K&N air filter?
Here is one, of more than one, thread on them: http://cb1100forum.com/forum/showthread....ight=K%26N
05-22-2015, 02:48 AM
Threads: 44
RE: K&N air filter?
Thanks, popgun - really odd, I ran searches twice before I posted this, and only got results of mentions of the filter within another subject, nothing this specific. I was POSITIVE that I'd read something like the above. Thank you -
05-22-2015, 03:18 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
RE: K&N air filter?
Between what I've learned on the dirt bike forums and the Guzzi forums; the K&N does NOT protect your motor from fine particulates and the stock filter breathes well enough that I'll never buy a K&N again.
Made sense back in the carb days; but not today.
Typically when I respond that the stock system breaths pretty good already folks post in disbelief; then I look at the area of the intake snorkel on my F150 3.5L Ecoboost motor, pretty much the same size as my 1.2L normally aspirated Guzzi engine and I stand my ground. These modern motors breath pretty darn good and unless you affect the whole air pumping train from intake to exhaust and the valve timing and ECU programming all you are doing is giving money to K&N. And probably increasing intake noise.
05-22-2015, 04:48 AM
12cb96vfr_imp Offline
Threads: 27
RE: K&N air filter?
yeah man I have a K&N and I don't notice any difference whatsoever....I ride enough that it was worth it from the clean & reuse standpoint.
05-22-2015, 07:31 AM
  PCV maps for cat delete and K&N filter… SoCal CB1100_imp 2 251 01-03-2022, 11:55 AM
  Moriwaki Micron Oil Filter Henrik_imp 8 704 09-15-2021, 01:09 PM
Last Post: LikeAfox_imp
  Vermin in the air filter! Skypilot_imp 25 1,584 06-25-2019, 02:01 PM
  BMC Air Filter aschem_imp 6 572 05-01-2016, 05:22 AM
Last Post: Gumby 1100_imp
  Arrow Headers (center stand and oil filter question) MikeOxbig_imp 4 363 09-09-2015, 11:59 PM
Last Post: veech_imp
  Yoshi system - oil filter removal Razor 7 567 07-19-2015, 10:34 PM
Last Post: Razor
  Air Filter change xNE0x_imp 4 351 02-14-2015, 10:57 AM
Last Post: xNE0x_imp
  Oil Filter Cover? NightRider_imp 11 680 08-27-2014, 10:26 PM
Last Post: redbirds_imp
  New Air Filter Darpo_imp 16 982 11-18-2013, 08:54 AM
Last Post: CB4ME_imp
