Arrow Headers (center stand and oil filter question)
MikeOxbig_imp Offline
Threads: 8
I did a search so please don't kill me. Just want a quick confirmation, if I get the Arrow headers can I still use the center stand, and also can I still access the oil filter without removing the headers?
Also, my understanding is I will need to either get an ECU re-flashed or get a power commander correct?
Thanks in advance.
09-09-2015, 08:40 AM
Motogeezer1949_imp Offline
Threads: 66
RE: Arrow Headers (center stand and oil filter question)
If you want to remove the top speed limiter a reflash is required.
09-09-2015, 10:18 AM
rusty1_imp Offline
Threads: 4
mikeoxbig, yes the center can be retained and you can change oil filter with pipes on. I like the look and sound, I put a sp tadao two tails mufflers on, because I wanted muffler on each side.
But I would get a pcv and dyno tune it. If that is the only mod you are doing down the pcv program and sent your ecm to guhlmotors.
09-09-2015, 03:05 PM
Threads: 8
Thanks Rusty1! Nice bikes btw, your garage is like a flashback to the 70's and 80's!! Very cool. I think I will consider those arrow headers sometime soon (arrow slip is on the way).
A few questions for you: (Or just provide the link if already posted on this forum)
Do you have the reflashed ecu or pcv? Or both?
Did you lose any low-end or mid-range torque after the exhaust upgrade?
How noticeable is the power increase?
09-09-2015, 04:01 PM
veech_imp Offline
Threads: 3
Great looking paint job rusty1! Thumbs Up
09-09-2015, 11:59 PM
  Stand-alone ECU TTRacer_imp 2 309 02-22-2024, 01:58 PM
Last Post: TTRacer_imp
  Arrow Slip-On Thoughts le_penseur_imp 84 5,679 05-15-2023, 05:20 AM
Last Post: mrded_imp
  Arrow exhaust. Mixagon_imp 11 939 10-25-2022, 01:56 AM
Last Post: ymtnpoah11_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,648 07-23-2022, 06:02 PM
Last Post: rich_imp
  Arrow full exhaust gretle_2.0 2 356 05-17-2022, 11:38 AM
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,356 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  PCV maps for cat delete and K&N filter… SoCal CB1100_imp 2 255 01-03-2022, 11:55 AM
  Moriwaki Micron Oil Filter Henrik_imp 8 704 09-15-2021, 01:09 PM
Last Post: LikeAfox_imp
  loose the arrow jimgl3_imp 33 2,055 08-30-2021, 11:14 PM
  Does anyone have Delkevic headers? Gordo_imp 9 885 06-22-2021, 12:10 PM
Last Post: Gordo_imp
