- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
Road comet 1 on 2014 vibration.
| Author |
Message |
walrusz06_imp
Threads: 7
Hi there. I recently received the road comet for my cb 1100. I installed it today, great quality etc.
However I'm noticing some pretty heavy vibrations. Have any of you noticed this? Any suggestions to fix?
Mostly around 2000 rpm. It's not hitting something on the bike like gauges etc. seems the fiberglass housing just resonates...
Nick
| 06-29-2015, 11:46 AM |
ChipBeck_imp
Threads: 29
RE: Road comet 1 on 2014 vibration.
Nick,
I have a Road Comet on my CB11 and I have no vibration at all. Does it vibrate while on the center stand at 2000 RPM in gear or does it just vibrate at speed which might indicate a wind vibration? Yours is the first account of this and it would be interesting to know what's causing it.
Chip
| 06-29-2015, 12:21 PM |
walrusz06_imp
Threads: 7
Also on the center stand. It's engine induced. Samurider said try adjusting but I'm not sure which way to adjust it.
| 06-29-2015, 08:33 PM |
veech_imp
Threads: 3
Road Comet 2 on a '13 with zero vibrations at any speed. Did you chech if the nuts are all tight on the bracket that mounts underneath the horns? Sounds like something might be loose somewhere...
| 06-29-2015, 09:34 PM |
the Ferret
Likes Given: 753
Is it a buzz? Maybe during installation one of the connectors inside the headlight shell got jostled enough to make contact with the headlight shell. Some have had that happen. Wrapping the connectors with foam cured that problem and made their buzzing go away.
| 06-29-2015, 09:39 PM |
walrusz06_imp
Threads: 7
It's a clear vibration from the comet. If I hold it down with my hand and rev engine it goes away.
All this no big deal when underway as any wind noise blocks out all other sounds.
| 06-29-2015, 11:24 PM |
veech_imp
Threads: 3
The way you have it mounted may be close to the gauge housings and they may be contacting the fairing. Try wedging a pencil eraser in between the two to see if that takes care of it. If all the mounting hardware is tight then you may need to loosen it, readjust, and then retighten.
| 06-30-2015, 12:07 AM |
HikerToo_imp
Threads: 114
Mine had a bad vibration too, and others who I got the solution from said to put two rubber "stops" that wedge between the screen and top of gauges, ( one on each side) that fixed mine and they have never fallen out.
I used those rubber feet, sticky on one side that are about 3/8" tall and wide you can get at hardware stores.
You can kinda see them here in the start of the video, mine are white, I want to switch to black at some point.
| 06-30-2015, 12:28 AM |
Papa Weeley_imp
Threads: 44
Walrus, I have exactly the same problem on my '13. It's not terrible, but noticeable. Mine is definitely not touching anything, and everything is tight at mounting points - it just kind of buzzes at certain RPMs. It hasn't bothered me enough to attempt to investigate the cause and fix it yet, but it's on the list. I'll be watching here to see if you find something that works!
| 06-30-2015, 03:03 AM |
veech_imp
Threads: 3
I'm curious, you guys who are experiencing the vibrations, do you all have Road Comet 1 models?
| 06-30-2015, 04:22 AM |
| Possibly Related Threads… |
| Thread |
Author |
Replies |
Views |
Last Post |
power port and Samurider Road Comet Fairing 1 |
tdbru |
9 |
973 |
05-04-2025, 07:20 PM
Last Post: tdbru
Road Comet Masqeroad: A Beautiful Pragmatic Response |
rdprdp01 |
7 |
962 |
05-04-2025, 11:33 AM
Last Post: rdprdp01
Road Comet: A Beautiful Pragmatic Response |
rdprdp01 |
12 |
974 |
10-29-2024, 12:25 AM
Last Post: rdprdp01
Wanted. Chick design comet 2 windshield |
Nightryder22_imp |
15 |
1,132 |
01-22-2023, 03:07 AM
Road Comet Fairing |
Catbird_imp |
47 |
4,223 |
08-16-2022, 10:33 PM
Road comet 2 fitment correct?? |
gretle_2.0 |
8 |
800 |
05-07-2022, 11:08 PM
Tall Riders and Comet striped shield |
Nightryder22_imp |
11 |
1,085 |
04-08-2022, 09:28 PM
Road Comet 2 Impressions |
Frulk_imp |
12 |
866 |
11-14-2021, 07:09 PM
Last Post: mrded_imp
road comet fairing |
vfrpaul98_imp |
75 |
5,001 |
10-21-2021, 02:41 AM
Saturday morning project - Road Comet 2 Fairing |
LuckyNLife_imp |
11 |
895 |
09-16-2019, 11:36 PM
Last Post: Cobalt23_imp
