Anybody gear lower for the drag-strip?
jeffskar_imp Offline
Threads: 7
Just wondering if anyone has installed a smaller drive sprocket, or a larger wheel sprocket to see what kind of gains could be had at the drag strip? I know everyone wants more power, more sound, and most times higher final gear ratios, but just curious if anyone has done this yet, and what resulted.
09-05-2015, 06:46 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Anybody gear lower for the drag-strip?
Without a reflash it won't do you a whole lot of good as the bike hits the speed limiter in the ¼ mile with the stock gearing.
09-05-2015, 07:05 AM
Threads: 7
The track I usually go to is actually an eighth mile track, so I'm bettin I won't be much over 80mph through the traps. Where is the top speed limiter set on these things, I think I've been about 110-115 on mine a time or two?
09-05-2015, 12:39 PM
Likes Given: 789
Approx 112 mph. besides the top speed limiter there is also a rev limiter in several gears
09-05-2015, 12:46 PM
Threads: 7
Hopefully not below 8500rpm, I can't really see needing any more rpm than that for these bikes?
09-06-2015, 12:44 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Jeff, most who have reflashed the ECU have the speed limiter removed and the rev limiter moved up 500rpm. There is a TON of info on this if you search for ECU reflash or Don Guhl.
09-06-2015, 12:48 AM
Likes Given: 789
Max horsepower on these bikes is at 7300 rpms, max torque at 5800
Interesting thread on the limiters
http://cb1100forum.com/forum/showthread....ev+limiter
Another on a reflashed CB
09-06-2015, 03:20 AM
  Lower Footpegs CB4ME_imp 21 1,542 04-12-2023, 01:37 AM
  How to lower seat for short-legged "freeks" Crossfire_imp 25 1,820 01-30-2022, 06:45 PM
Last Post: jtopiso_imp
  Custom fender eliminator & 2017 grab bar with LED strip tail light mod CBhooligan_imp 33 2,723 05-10-2020, 06:24 PM
Last Post: Jfro5687_imp
  How to lower your CB1100 modmaster_imp 21 1,412 12-08-2018, 10:55 PM
  Attaching led strip light to running light? The Beast J7_imp 6 665 06-28-2018, 12:58 PM
Last Post: The Beast J7_imp
  Lower gearing? Anyone done it? Magnus_imp 10 777 04-19-2016, 10:18 AM
  Sprockets Lower RPM 1953andrejrigoli_imp 4 404 03-17-2015, 08:37 PM
Last Post: CIP57_imp
  Lower Handlebars & Fork Boots DGShannon_imp 4 388 10-08-2014, 12:48 AM
Last Post: DGShannon_imp
  Fender elimination / Drag bars Joel Goodson_imp 10 634 04-20-2014, 09:22 PM
Last Post: Joel Goodson_imp
