Attaching led strip light to running light?
The Beast J7_imp Offline
New to the Forum
Threads: 1
I have 2 short 6 led light strips, each with 2 small wires, one red and one black.
Question, is, is it ok / possible to attach these to my front turn / running lights?
However I only want to attach them to the running light only, not the turn signal.
Do I need anything special? Plead advise!
06-26-2018, 11:03 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Attaching led strip light to running light?
The short answer is no. A longer answer will have to wait until I can get on a real keyboard. The better way is to use the accessory connector in the headlight shell. It has 12v when the ignition is on.
06-26-2018, 09:05 PM
New to the Forum
Threads: 1
(06-26-2018, 09:05 PM)Lord Popgun_imp Wrote: The short answer is no. A longer answer will have to wait until I can get on a real keyboard. The better way is to use the accessory connector in the headlight shell. It has 12v when the ignition is on.
Thank you! Not sure what that looks like, will have to get a service manual that has a wiring diagram. but thanks, that was an angle I was not thinking about.
06-27-2018, 08:43 AM
SportsterDoc Offline
New Mexico
Threads: 33
Likes Given: 6
If I recall correctly, the accessory connector is red.
The reason for not connecting to running lights is that Honda uses a single element bulb with lowered voltage as a running light and full voltage when it flashes for a turn.
06-27-2018, 08:46 AM
egleaves_imp Offline
Threads: 11
I put some of those strip lights on my bike, but I tapped straight into the headlight circuit at the fuse box with on of these:
https://www.amazon.com/dp/B0742BZXC2/?co..._lig_dp_it
Super easy way to tap the fuse box, but then the fuse box cover doesn't fit right anymore. I mounted the strip lights under the frame and they light up whenever the ignition is switched on.
06-27-2018, 08:53 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Beast, go here for a wiring diagram: http://cb1100forum.com/forum/showthread....#pid199015
It is post 8. Click on the red here at the bottom.
Like Sportsterdoc says, the accessory connector is red and is capped. Just for info, there is another one under the tool tray in a boot on the left side of the bike. Removal of the left side panel helps with accessing it.
Anyway, remove the headlight, looking into the shell, the connector is on the left towards the bottom. It may be taped and is a 2 pin connector.
One wire is green and is ground. The other is 12v when ignition is on. But you should verify with a meter in case of a factory wiring error.
Unless you have a connector shell, pins, and the proper crimp tool for Hitachi connectors, you will have to either tap the wires or cut off the connector and butt splice (or solder if you know how) the connections. Know that there are no known accessories that plug into the accessory connectors. Except for the various add ons that members have come up with, like your LEDs, USB charging ports, etc.
06-27-2018, 09:15 AM
New to the Forum
Threads: 1
(06-27-2018, 09:15 AM)Lord Popgun_imp Wrote: Beast, go here for a wiring diagram: http://cb1100forum.com/forum/showthread....#pid199015
Thank you all............. gona look into it.
06-28-2018, 12:58 PM
  Preferred Brake Light Bar Farkles TooManyBikes_imp 12 1,470 03-18-2024, 02:46 AM
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,699 07-06-2021, 10:00 PM
  License Plate/Tail Light Bracket eddi0_imp 0 246 03-08-2021, 09:42 AM
Last Post: eddi0_imp
  Another Driving Light thread (Black Oak LED) bflint 10 984 08-18-2020, 04:20 AM
Last Post: bflint
  Tail-light Mount eddi0_imp 5 507 08-16-2020, 11:15 AM
  Light pod in windshield? bflint 6 664 08-12-2020, 02:42 PM
Last Post: bflint
  Killing the Buzz - Installing "Even Running" Cam? M3-SRT8_imp 8 771 08-02-2020, 03:17 AM
Last Post: M3-SRT8_imp
  Interesting Helmet light options satchit 1 343 06-21-2020, 02:59 AM
  Custom fender eliminator & 2017 grab bar with LED strip tail light mod CBhooligan_imp 33 2,765 05-10-2020, 06:24 PM
Last Post: Jfro5687_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,327 04-17-2020, 07:25 AM
Last Post: gman_imp
