Fitting Yoshimura Centre Stand Stopper
beardyweirdy@me.com_imp Offline
Threads: 31
Hi all,
Eventually, after a three month wait, my Yoshimura Centre Stand Stopper has arrived... But with no fitting instructions, fitting kit, etc.
Has anyone fitted fitted one on here?
It's a fairly hefty bracket and it looks to me like it fits over the top of the centre stand lugs on the frame.
I'm thinking I should remove the CS spindle, slip the CS stopper over the frame lugs for the CS and then re-fit the CS spindle.
I'm going to have a go at it on Wednesday, but if anyone's got any advice, it would be great to hear it... Or put me right if I'm off the mark with the fitting.
Many thanks
Kev
11-01-2015, 11:14 AM
veech_imp Offline
Threads: 3
RE: Fitting Yoshimura Centre Stand Stopper
Installing this is a bit of a pain. Hopefully you have the hardware as some of it needs to be swapped from stock. Here are the installation instructions.
11-02-2015, 04:28 AM
Threads: 31
Thanks for that veech. I'll have a look and see if it helps any, but mine is for a 2014 model and its a different looking beast. Much more stout. I'll take a pic and post it up, see if anyone has any ideas. Thanks tho, I'll see if the principal looks the same on the one you've posted the link too. Actually, they may have the instructions for the 2014. Where did you find the pdf?
Thanks
Kev
11-02-2015, 09:51 AM
Rick Froscheiser_imp Offline
Threads: 5
I believe you can find them on the Yoshimura web site.
11-02-2015, 01:35 PM
veech_imp Offline
Threads: 3
You're very welcome, and yes the instructions are on the Yoshi website. If you need any parts at all call Yoshi USA (contact is also on the website.) They are very helpful and with the instruction sheet you can find any part number and order directly from them. I had to get a new clamp and they sent one right out.
11-03-2015, 01:32 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 676 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Stand-alone ECU TTRacer_imp 2 310 02-22-2024, 01:58 PM
Last Post: TTRacer_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,813 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,862 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,650 07-23-2022, 06:02 PM
Last Post: rich_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,360 01-05-2022, 10:54 PM
Last Post: Nibis_imp
   Rlet's simple fitting Mixagon_imp 13 954 05-24-2021, 12:07 PM
  Pit Bull Rear Stand Stichill 7 632 05-02-2021, 04:45 AM
Last Post: ampm7_imp
  Spools for pit stand. kmoney_imp 12 1,416 03-25-2021, 12:09 PM
Last Post: Obleo
  Dimotiv Side Stand Enlarger - 2017 EX fit TXBikerGuy 5 639 08-08-2020, 09:48 AM
Last Post: TXBikerGuy
