- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
Goldwing Rider Pegs (wider than stock ones)
| Author |
Message |
Huladog_imp
Threads: 23
In case you've never sat on a late model Honda Goldwing it may surprise you that they come with wider rider pegs and not floorboards like you might expect.
As I mentioned in another topic thread I had read about using the Goldwing pegs on the current CB300's and CB500's and knew the Honda foot peg mounting system is the same across the model line up so I went ahead and ordered a set of replacement pegs on eBay to give it a shot.
Camera angle is misleading, they're not that huge:
The installation is simple enough, remove the cotter pin, pull up the pivot pin, watch out for the washer and spring, then do the reverse to install the new peg. Don't be like me and forget to replace the washer and you have to take it all apart again. Or, you spend more time fiddling with the peg return spring getting it all lined up just right so the pivot pin slips back into place.
Right side, no problems, no issues:
Left side? Discovered I needed to loosen the bolt holding the shift lever to give me enough room to remove the pivot pin, then I discovered there isn't enough clearance between the shift lever and the Goldwing peg! Not a big problem, just need to bust out the Dremel and grind the peg a bit tonight.
Looks worse in these photos than in real life ..... I hope.
Happy to be the guinea pig for you all! Will post an update after I grind that interference away.
Aloha,
Huladog
| 05-12-2016, 06:21 AM |
Papa Weeley_imp
Threads: 44
RE: Goldwing Rider Pegs (wider than stock ones)
Awesome - will be interesting to see how that grind job works out!
Thanks for the post!
| 05-12-2016, 06:33 AM |
c-breezy_imp
Threads: 11
| 05-12-2016, 06:48 AM |
immgunn_imp
Threads: 6
What a cliffhanger.
Looks like a worthwhile mod. I'm anxiously awaiting for "The Rest of the Story"
| 05-12-2016, 02:18 PM |
rboe
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
Thanks! I've been wondering, as the Moto Guzzi Norge riders recommend the Gold Wing pegs as an upgrade to the Norge units for more comfort.
| 05-13-2016, 02:47 AM |
Huladog_imp
Threads: 23
Installation Part 2: Oh-oh more issues to deal with
Sorry I took so long to get to Part 2 but when I started the peg installation I did it before I went to work the other day and only had time today to complete it since I took a day off to visit the doctor.
Grinding some relief for the shifter bolt was no big deal, went pretty fast and probably took me longer to gather up my tools than it took to grind a little aluminum away.
Shop Safety Talk: Wear some kind of eye protection because the Dremel will throw up a bunch of tiny metal chips that would hurt like hell if they get in your eye. You'll see the tiny chips in the following photos.
Right about now I said "oh-oh, the shift lever rubs against the inside of the peg". Never thought about that. The CB11 is really built to some tight tolerances and the stock peg has enough clearances around it that none of this is an issue until you start messing around with stuff that was never designed for the CB11 in the first place.
Yellow arrow shows you the new clearance with the shifter bolt. Red arrow shows you where I started noticing interference with that rounded off end to that pin and later with the bend in the shifter lever.
Dremel to the rescue and this time it took a lot longer to grind a bit, test the fit, grind some more, test fit some more. Your experience may vary due to slight differences in aftermarket "Goldwing" pegs from overseas. The aluminum alloy they use in the stock pegs and the aftermarket pegs isn't very hard so a Dremel makes quick work of it, just take it slow and careful even though you will never see your handiwork in daily use.
Yellow arrow shows you the curved relief I ground for the shift bolt. Red arrow shows you the area on the inside of peg that needed to be ground down for relief from the shift lever and protruding pin.
View from the top shows you the clearance I needed to grind.
And lastly, using the super-high-tech-LED-lighted-mirror-on-a-stick that I learned about using to check your oil level while sitting on the bike (from another forum topic) I checked the clearance from below while working the lever just to be sure.
I also checked the clearance by slipping a scrap of thin cardboard into the gap and worked the lever and watched to see if the peg moved at all.
Looks good but just to be super-sure I rubbed a blue Sharpie all over the shifter lever and inside of the peg like a DIY machinist's bluing so I could see if it rubbed while riding later.
You want to know how careful Honda seems to be when building our bikes? Do this mod and the very first step is to bend back the ends of the cotter pins securing the peg pivot pins, you'll see that the factory carefully folded the ends of the cotter pins around the peg pivot pin so it follows the curve of the pin and it'll take you a little time to find a small screwdriver or utility knife blade in order to simply pry those carefully folded ends of the cotter pins away so you can straighten then out to be removed!
Aloha,
Huladog
| 05-13-2016, 09:30 AM |
rboe
Phoenix, AZ
Threads: 64
Likes Given: 7
Next: Ride report!
| 05-13-2016, 10:15 AM |
Matt F._imp
Threads: 6
Great write up! Thanks for sharing. Oh yeah this is happening to my CB for sure
| 05-13-2016, 03:03 PM |
Chapomis_imp
Threads: 64
Thanks for all the R&D, nice job.
| 05-13-2016, 06:36 PM |
Lord Popgun
El Supremo RLET Force
Virginia
Likes Given: 142
Ferret or Cormanus,
Any chance this could go in the HOW-TO section? Would be easy to find in the future instead of having to search around for it.
| 05-13-2016, 08:47 PM |
| Possibly Related Threads… |
| Thread |
Author |
Replies |
Views |
Last Post |
Stock Mirrors |
MrBob_imp |
5 |
610 |
04-11-2025, 03:33 AM
Last Post: balkanhound_imp
Stock Exhaust Mod |
SStan11_imp |
79 |
5,566 |
03-12-2025, 04:32 AM
Foot pegs |
Nick_imp |
3 |
443 |
01-02-2025, 04:14 AM
Stock Muffler |
jbird06_imp |
8 |
755 |
05-02-2024, 11:21 AM
3D printed strap adapters for the CB1100 mounting pegs |
LayerCake_imp |
33 |
2,500 |
07-10-2022, 12:04 AM
Last Post: 1973cb750
Help me find parts to mount highway pegs please |
LikeAfox_imp |
23 |
1,805 |
05-24-2021, 10:03 PM
Last Post: LikeAfox_imp
Wider handlebars, Tracker style. |
JLEECB |
18 |
1,955 |
05-16-2021, 09:31 PM
Last Post: Zee9_imp
New Seat, Pegs, etc. |
aschem_imp |
16 |
1,308 |
10-14-2020, 01:02 PM
Last Post: dhubbard422_imp
Decat stock pipes |
ozigoo |
4 |
491 |
05-22-2020, 10:55 AM
Stock vs. aftermarket exhaust |
LongRanger_imp |
15 |
1,129 |
11-30-2019, 06:30 AM
