Turn signal relocation and license plate bracket
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
I found this bracket while doing my own custom relocation. It would require two holes to be drilled to bolt to the fender. I have not used it myself but thought someone else may like it.
http://www.kuryakyn.com/products/3908/li...ght-mounts
07-30-2016, 06:34 AM
Likes Received: 619 in 277 posts
Likes Given: 789
RE: Turn signal relocation and license plate bracket
Why couldnt you bolt that to the lic plate bracket and not have to drill any holes?
07-30-2016, 07:58 AM
Gumby 1100_imp Offline
Threads: 17
(07-30-2016, 07:58 AM)The ferret_imp Wrote: Why couldnt you bolt that to the lic plate bracket and not have to drill any holes?
The photo above shows the two central counter sunk holes that would need to be drilled in order to mount to the licence plate bracket attached to the fender. And, if the spacing is similar to mine, you might also need to add a couple of thick washers behind the drilled holes, so that the new plate does not touch the fender at the bottom.
07-30-2016, 09:44 AM
Likes Given: 789
Ahh gotcha.
07-30-2016, 10:36 AM
  Turn Signal Indicators balkanhound_imp 5 700 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,539 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,652 07-23-2022, 06:02 PM
Last Post: rich_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,652 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 745 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  License Plate/Tail Light Bracket eddi0_imp 0 245 03-08-2021, 09:42 AM
Last Post: eddi0_imp
  Turn Signal Relocation Cormanus 11 922 12-30-2020, 11:12 AM
  Where to get a seat pan/plate? Sodbuster_imp 4 548 10-26-2020, 10:53 PM
Last Post: Sodbuster_imp
  The 2013/2014 Yoshimura Centerstand Bracket Issue Rox_imp 0 250 07-28-2020, 02:40 PM
Last Post: Rox_imp
  Honda "Power of Dreams" License plate frames pekingduck 15 1,232 06-01-2020, 11:24 AM
Last Post: TXBikerGuy
