Installing New Grips
Joola_imp Offline
Threads: 12
I just received the Pro Grip 719 open end gel grips I ordered but I've never switched out grips myself before. Anyone whose done this with their CB have any pointers? Do I need to cut off the old grips or can I pry them off? Do I need to buy glue for the new grips (they didn't come with any)?
Any advice is appreciated!
06-28-2013, 12:57 AM
Dynaguy_imp Offline
Threads: 0
RE: Installing New Grips
I can't address the CB1100, but I've replaced grips on a number of my bikes. They vary in what is required as you might expect. An air compressor helps a ton. On open grips like the Honda has, simply put your needle valve in you air compressor hose, slightly insert it under the end of the grip while encircling the end of the grip closest to the controls and when a little air is applied, the old girp can be simply slipped or "walked" off. The new grip can be attached pretty much the same way. Most new grips I have used are so tacky that glue is not needed. If your throttle grip is glued on, prepare for a long day.
06-28-2013, 01:31 AM
furious_blue_imp Offline
Threads: 11
On past bikes I didn't bother trying to 'be nice' to the old grips. I just slit the old grips open with a knife and peeled them off. Be careful cutting on the throttle side for obvious reasons. Done in a minute of less glued on or not. No preparation, no air. If the old grips were glued on add to that a few minutes using a solvent/scraper to get the old glue off of the bars.
06-28-2013, 01:47 AM
Flynbulldog_imp Offline
Threads: 6
I've done this dozens of times.
Slip a long slim dull or rounded screwdriver under the grip all the way in. Use the straw on a can of wd 40 and insert it next to the screwdriver and spray.
Remove the screwdriver and twist - the grip will slide right off.
Clean the inside thoroughly for re-installation.
To install use no glue. Liberally spray Windex inside the grip (the alcohol dries quickly and the soap aids installation and when dry acts as a glue) and slide the grip in place, let it dry over night.
I never ever use glue to install grips.
06-28-2013, 01:54 AM
oldyaler_imp Offline
Threads: 2
(06-28-2013, 01:31 AM)Dynaguy_imp Wrote: I can't address the CB1100, but I've replaced grips on a number of my bikes. They vary in what is required as you might expect. An air compressor helps a ton. On open grips like the Honda has, simply put your needle valve in you air compressor hose, slightly insert it under the end of the grip while encircling the end of the grip closest to the controls and when a little air is applied, the old girp can be simply slipped or "walked" off. The new grip can be attached pretty much the same way. Most new grips I have used are so tacky that glue is not needed. If your throttle grip is glued on, prepare for a long day.
+1. Warm soapy water or an aerosol hair spray will make it easier to install the grips. Makes 'em slippery enough to slide right on, just make sure they're aligned fairly quickly, especially with the hair spray.
06-28-2013, 01:55 AM
Threads: 11
(06-28-2013, 01:54 AM)Flynbulldog_imp Wrote: I've done this dozens of times.
I'll have to try it this way next time !
06-28-2013, 01:57 AM
CBMike_imp Offline
Threads: 0
Just helped my buddy do grip swap on his thruxton. Since we didn't have a air compressor, which makes grip changes the easiest thing ever, we used WD40 to get the old ones off and hairspray when putting them on as others have said above. Works every time.
06-28-2013, 02:10 AM
dBuster_imp Offline
Threads: 7
+1 on the WD40 and hair spray. Just don't let the wife/girlfriend/significant other know you took her hair spray. Smile
06-28-2013, 03:21 AM
Joola_imp Offline
Threads: 12
All excellent tips. Thanks guys. I'll be swapping my grips and mirrors out tonight in prep for a nice weekend of riding.
06-28-2013, 04:23 AM
Threads: 698
Likes Given: 792
Late to the party but I use the air compressor to blow off the old grips and blow on the new grips.
I assume you know the softer thinner grip goes on the throttle side
On 719s the pattern needs to be paid attention to in the grip, think about how your hand goes around them, then orient before installation
Here is how I orient mine
[url=http://smg.photobucket.com/user/theferret111/media/2013_04270021_zpse23edc7c.jpg.html][Image: 3aa61521714b15a75df3be21f2c7c9af.jpg]
06-28-2013, 05:31 AM
  Fork Gaiters and Heated Grips tdbru 20 3,099 05-02-2025, 11:16 PM
  Spare connectors/Oxford heated grips White Dog_imp 13 1,594 04-18-2025, 10:02 AM
  need help installing slip on exhaust nw suburb, IL jm0327_imp 18 1,694 10-25-2024, 12:12 PM
Last Post: iamheero_imp
   HEATING GRIPS ICON HONDA ORIGINAL NON-OPERATING CB1100 ex 2015 EUROPE. COMPLAINT TO Alfgaxatico_imp 16 1,885 12-10-2020, 07:35 AM
Last Post: Alfgaxatico_imp
  hand guards and heated grips misterprofessionality 33 2,499 11-16-2020, 10:06 AM
Last Post: mrded_imp
  thicker grips active1951_imp 15 1,206 08-04-2020, 12:55 PM
Last Post: gmike_imp
  Killing the Buzz - Installing "Even Running" Cam? M3-SRT8_imp 8 760 08-02-2020, 03:17 AM
Last Post: M3-SRT8_imp
  Making closed end grips work on the CB Skypilot_imp 6 652 05-18-2019, 10:40 AM
  OEM ONLY HEATED GRIPS peterbaron 4 590 10-09-2018, 10:59 AM
   Good grips for CB1100? Which ones are you all installing? rdtshaw_imp 61 4,584 08-06-2018, 11:47 PM
Last Post: itstuantran_imp
