Looking for seat suggestions
noah_imp Offline
Threads: 2
I've done a bit of forum searching, but didn't see anything which covered this particular case.
I'm pondering the purchase of a '17 EX. Took a test ride on one the other day and the seat appears to be putting pressure on my perineum; the effect of which, while relatively minor, became noticeable after only 15 minutes. Also it felt a bit cramped, and I've no idea what that'll be like after a few hours since for some reason the dealers look at you funny when you ask.
I've purchased custom seats before; I've got a Day-Long on my DL650 which is the best seat I've ever owned, but I think it'd look a bit wonky on a CB. I'm all about function before aesthetics, but if function can be solved in a way which also looks good, so much the better. So, here's the question: anyone else have this particular problem and, if so, with what seat did you replace the stocker? If it helps:
5-11
180
32" inseam
Goals:
* all-day comfort. Yes, I take breaks, but even so.
* probably some extra height; I'm spoiled by my Vstrom and am used to a far less cramped position. Looking at lower legs to help solve this, but I may need both.
Bonus points are awarded if you have such a seat, live in the D.C. Metro area and don't mind me coming out and throwing a leg over (not to take the bike out, just to check out the seat).
Cheers.
06-06-2018, 10:34 AM
Houtman_imp Offline
Threads: 115
RE: Looking for seat suggestions
My CB 1100's became more comfortable with Corbin seat (higher version) and Vario foot pegs . 6 ft/220 lbs 32 inseam
06-06-2018, 10:45 AM
noah_imp Offline
Threads: 2
(06-06-2018, 10:45 AM)Houtman_imp Wrote: My CB 1100's became more comfortable with Corbin seat (higher version) and Vario foot pegs . 6 ft/220 lbs 32 inseam
Questions:
1. What length extension did you opt for on your Varios? Notice any loss of lean angle? I don't generally scrape pegs, but still. Smile
2. Did you also install bar risers? If so, how high?
06-06-2018, 10:54 AM
PowerDubs_imp Offline
Threads: 125
I am also 5'11 32 leg- and I find this seat perfect. Note that while the pegs are stock, the handlebars are not.
[Image: 15dabcd8d02ecd46bc67cf2d8b020d70.jpg]
06-06-2018, 11:04 AM
noah_imp Offline
Threads: 2
(06-06-2018, 11:04 AM)PowerDubs_imp Wrote: I am also 5'11 32 leg- and I find this seat perfect. Note that while the pegs are stock, the handlebars are not.
I found the thread with info on your bars; thanks. What seat is that?
06-06-2018, 11:34 AM
Houtman_imp Offline
Threads: 115
23 mm on the Vario and no risers , the handle bars are perfect for me.
I tried the 30 mm ones but that was too much.
06-06-2018, 08:33 PM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
If you're looking for all day comfort, what you need is wide and relatively flat (just like the old days). I found the stock seat OK, until I rode it on an 8 hr. day. The stocker angled me down toward the tank, and the skinny part of the seat.
I replaced it with a wide, flat Tiros K seat from Samurider (by way of forum member Kenny). It's flatter, firmer and taller and 10 hr. days are a piece of cake for me. Doesn't hurt that it also gives the bike a more classic look.
I think Samurider only sells a pricey leather version of that seat now, but I think you'd get similar results from something like the Daytona Cozy.
[Image: 4b45ad9e4b130144c0451b7fc365380b.jpg]
Quite a few forum members have gone with the tried and true Corbin. I think you have the right idea about trying one yourself. Seats (like windshields) are a very individual choice.
06-06-2018, 08:37 PM
jimgl3_imp Offline
Threads: 27
luimoto! get you some gold gel.
https://www.luimoto.com/
06-06-2018, 09:16 PM
Knave_imp Offline
Threads: 1
I ordered the flat seat from Samurider and requested it be made an inch taller. I'll report back once I get it. I'm 6'3 with a 37 inseam .
06-06-2018, 10:16 PM
Nortoon_imp Offline
Threads: 28
There is a thread on the taller seat from Samurider soon being available for the 2017 EX.
I am 6'2" tall and weigh 125 pounds. I would get uncomfortable after 1 1/2 hours of riding on the Honda seats on both my CB500XA and CB1100 EX.
I was lucky and bought a seat from a forum member that had been modified to be taller and softer. Looks similar to the K seat. I also added GenMar pull-back risers to get a more straight up riding position. Now I can ride comfortably for 2 hours.
I am 72 years young, and find that I get tired riding any longer than that. It then becomes an endurance test rather than an enjoyable ride in the country. It can also get dangerous if I am riding enthusiastically as my sweeping through the twisties becomes clumsy. So I always plan for 15 minute rest stops and 1/2 hour stops for breakfast and lunch.
06-06-2018, 11:33 PM
  Any suggestions for front and rear cameras? Davidjill_imp 2 343 10-14-2024, 11:19 AM
  Hard luggage suggestions? run-tmc_imp 35 2,190 03-28-2022, 09:55 AM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 904 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 310 04-25-2021, 04:47 AM
   Any suggestions on shorter aftermarket shock? FLYTYM_imp 7 752 01-30-2019, 06:02 PM
Last Post: Desert viper_imp
  Handlebar holder suggestions? astyles_imp 1 280 08-10-2018, 02:49 AM
Last Post: tnelson99_imp
  Playing dress up, looking for suggestions misterprofessionality 36 2,477 04-27-2018, 02:06 AM
Last Post: guitar gord_imp
  Shad rack discontinued. Alternate suggestions? Jchills_imp 11 953 11-11-2017, 08:51 AM
Last Post: Dude_imp
  Suggestions on saddlebags that fit and look good. danielquin_imp 8 530 05-26-2014, 11:52 PM
Last Post: HikerToo_imp
