 Any suggestions on shorter aftermarket shock?
FLYTYM_imp Offline
Threads: 82
I plan on lowering the back of this bike a lot and need some shock suggestions,I believe the stock length is 340MM correct?
05-21-2018, 09:34 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Any suggestions on shorter aftermarket shock?
This thread, first post, mentions using Triumph shocks. http://cb1100forum.com/forum/showthread.php?tid=9190 On the second page of the thread lowering links and a source are mentioned.
I think a few members have used the Triumph shocks but I didn’t feel like reading all the search results Smile
05-22-2018, 05:25 AM
beardyweirdy@me.com_imp Offline
Threads: 31
Might be worth working out the ideal length of shock you need and asking a manufacturer what they have that will fit our bikes. Hagon in the uk have been very helpful to me and I know they have an outlet in Cali. Could save you a lot of sucking and seeing...
05-22-2018, 04:19 PM
jtopiso_imp Offline
Threads: 13
(05-21-2018, 09:34 PM)FLYTYM_imp Wrote: I plan on lowering the back of this bike a lot and need some shock suggestions,I believe the stock length is 340MM correct?
A good damper/suspension expert might be able to shorten the original damper rods and provide matching springs.
05-22-2018, 06:10 PM
Desert viper_imp Offline
Threads: 7
I just emailed you about some ICON 7610
01-30-2019, 02:05 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Stock 2013 CB1100 shocks are 360mm eye-to-eye length. There's no shortage of used 340mm long Bonneville (pre-2016) shocks out there. I've actually used them on several other bikes with fine results. I've bought them for as little as $30/pair.
The lower rubber bushing on the CB1100 is a larger ID than the top as I recall, and that's not normal so you may have to swap some bushings around.
I have a pair of 365mm Triumph Thruxton (pre-2016) shocks on my 2004 Bonnie and they improve the Bonnie's handling markedly. I might try them on the CB1100.
It would be difficult to take the stock shocks apart because there should be a jam nut above the rubber bumper, all covered by the shroud.
01-30-2019, 04:40 PM
FLYTYM_imp Offline
Threads: 82
I just emailed you about some ICON 7610 No email received.
01-30-2019, 05:48 PM
Threads: 7
I just emailed you about some ICON 7610 No email received. pm sent to you.
01-30-2019, 06:02 PM
  Any suggestions for front and rear cameras? Davidjill_imp 2 359 10-14-2024, 11:19 AM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,407 07-20-2023, 04:11 AM
  11-16 MY rear shock option - Europe/UK Tev62 0 215 02-13-2023, 05:29 AM
  Hagon Rear Shock Review dUh!_imp 2 467 09-18-2022, 10:55 PM
Last Post: KiowaEagle_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 686 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Hard luggage suggestions? run-tmc_imp 35 2,217 03-28-2022, 09:55 AM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 939 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  A question about shorter cables,brake lines. FLYTYM_imp 3 438 03-30-2021, 01:41 AM
Last Post: sonnyb_imp
  Rear shock recommendation please Jim_imp 12 1,017 09-25-2020, 11:25 PM
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 950 06-17-2020, 08:42 AM
Last Post: Mtneers
