Inlet and exhaust valve sizes
Bradders_imp Offline
Threads: 2
Does anyone know the inlet and exhaust valves sizes.
10-16-2018, 05:13 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Inlet and exhaust valve sizes
Doesn’t seem to be listed in the service manual.
10-16-2018, 06:09 AM
fritzwilliger_imp Offline
Threads: 3
(10-16-2018, 05:13 AM)Bradders_imp Wrote: Does anyone know the inlet and exhaust valves sizes.
Here's what I found:
Inlet valve diameter is 27mm, with a 2.5mm stem;
Exhaust valve diameter is 24mm, with a 2.5mm stem.
I assume that these specs apply to US bikes which have the same 1140 cc inline-4 motor, which is manufactured in Japan.
Link: https://hondanews.eu/eu/en/motorcycles/m...ress-pack3
Hope this helps!
-fritz
10-16-2018, 06:52 AM
Threads: 2
Thanks 2.5mm stem seems ultra small?
10-16-2018, 07:17 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Good find Fritz!! Think I’ll pencil that in my manual.
2.5mm does seem small. The manual says ...measure and record each valve stem O.D. SERVICE LIMITS: IN: 4.960mm (0.1953 in), EX:4.940 (0.1945 in)
It says to ream carbon deposits before checking valve guides using a 5mm reamer and gives the reamer part number. So I’m thinking the stems are 5mm?
10-16-2018, 07:36 AM
Threads: 3
(10-16-2018, 07:17 AM)Bradders_imp Wrote: Thanks 2.5mm stem seems ultra small?
Agreed! Wonder if somehow the 2.5 mm stem dimension listed refers to the radius instead of the diameter? That would be strange to switch from a diameter spec for the valve head to a radius spec for the stem. Anyone else know what's going on here?
-fritz
10-16-2018, 08:48 AM
peterbaron Offline
Likes Given: 996
AS per shop manual CB1100 2013-14
Valve stem O.D:
INTAKE : 4.970 - 4.995 mm , (0.1957 - 0.1967 in)
Service limit:.... 4.960 mm , (0.1953 in)
EXHAUST : 4.950 - 4.975 mm , (0.1949 - 0.1959 in)
Service limit :.......4.940 mm , (0.1945 in)
Hope this helps
10-16-2018, 09:09 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Hey Peter didn’t I post that 2 posts up? Big Grin
10-17-2018, 03:18 AM
peterbaron Offline
Likes Given: 996
(10-17-2018, 03:18 AM)Lord Popgun_imp Wrote: Hey Peter didn’t I post that 2 posts up? Big Grin
Maybe I am crazy = HuhROFL but I think you posted in # 5 service limits , not the specs...check pleaseSmile
10-17-2018, 03:29 AM
Threads: 2
Thanks guys
10-17-2018, 07:56 AM
  Tire Sizes ? Jayimpalaman_imp 4 411 07-29-2022, 06:57 AM
Last Post: Yata-Garasu_imp
  Stripped the valve cover PowerDubs_imp 25 1,620 11-18-2021, 10:19 PM
  valve stem replacement without removing tyre max 5 571 01-08-2021, 10:46 AM
   Clean pair valve..mod 3rdcoastcb1100_imp 14 1,214 05-22-2020, 09:58 AM
  Pair valve delete...i need photos -_- JohnHighlander_imp 2 292 05-30-2018, 05:21 AM
Last Post: Ferrealls_imp
  Tyre Valve Cap Replacements MrTim_imp 5 497 07-15-2017, 08:31 AM
  83 degree valve stems the Ferret 10 796 04-07-2016, 09:57 AM
Last Post: Pterodactyl_imp
  Will a CB1100 single exhaust fit the dual exhaust mountings Landy100_imp 1 278 05-02-2015, 09:44 AM
Last Post: Randy B
  Watch "cb1100 remus exhaust pair valve blocked" on YouTube fredkb_imp 14 1,070 11-23-2014, 01:43 AM
Last Post: fredkb_imp
  Arrow Slip On and PAIR Valve Mod Jettster_imp 5 428 06-09-2014, 09:00 AM
Last Post: kevbroce_imp
