longer length rear brake pedal
darmahman_imp Offline
Threads: 11
I wear a size 13 shoe and sometimes forget and the front of my foot rests on the brake lever. I was wondering if anyone has found a longer length brake lever arm ( runs parallel with the bike, not the part that sticks out to shift with)for my 13 shoe...
06-06-2022, 07:54 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: longer length brake lever
IIRC one guy cut his and had a piece welded in. I could be wrong though.
06-06-2022, 11:03 AM
mikeymike88_imp Offline
Threads: 2
(06-06-2022, 07:54 AM)darmahman_imp Wrote: I wear a size 13 shoe and sometimes forget and the front of my foot rests on the brake lever. I was wondering if anyone has found a longer length brake lever arm ( runs parallel with the bike, not the part that sticks out to shift with)for my 13 shoe...
I find myself wishing I could have more room between the peg and the brake lever every time I ride. I never considered a longer arm to be a possibility. Hopefully somebody chimes in with an easy solution, this would be amazing.
06-11-2022, 06:47 AM
Likes Received: 880 in 482 posts
Likes Given: 1,016
http://cb1100forum.com/forum/showthread.php?tid=5620
There is more to be found with the Search tool.
06-11-2022, 07:12 AM
  Don Guhl No Longer Tuning Motorcycle ECUs tj_gee_imp 45 3,128 03-08-2022, 02:48 AM
  ROX Risers and longer brake line? MrBob_imp 3 469 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Has anyone played around with lowering the brake pedal? Olyrider 8 661 06-06-2018, 02:31 AM
Last Post: RoyP_imp
  Longer shifter peg? Ghis_imp 11 853 02-03-2017, 04:10 AM
  Rear brake light flasher. walrusz06_imp 15 1,154 01-18-2017, 08:56 PM
Last Post: Rocky_imp
  Longer footpegs? ryanschillinger_imp 6 550 09-17-2016, 02:29 AM
Last Post: ryanschillinger_imp
  Rear brake light LENS removal DIY? Riko_imp 13 976 01-10-2016, 03:41 AM
Last Post: Riko_imp
  Where can I find longer brake lines? Inhouse Bob 32 2,270 09-05-2015, 10:35 AM
  Lowering the Brake Pedal Riverhustler_imp 4 500 04-26-2015, 10:02 PM
  Givi Rear Rack vs. Honda OEM Rear Carrier lagoje_imp 29 1,885 04-24-2015, 06:03 AM
Last Post: specialist8
