Where can I find longer brake lines?
Inhouse Bob Offline
Threads: 34
Likes Given: 15
Hi all,
I got some Rox Risers (2"), but the front brake line is too short to let me adjust them properly. Has anyone found a supplier for longer brake lines?
08-05-2015, 09:51 AM
kmoney_imp Offline
Threads: 29
RE: Where can I find longer brake lines?
There is probably a local company that can make them up for you wherever you live. I had a set of stainless lines made up for my other bike, made and pressure tested while I waited. It was just a place that specialized in industrial hoses and fittings. Though it requires some searching, this is probably easier than getting any of the big guys (Galfer, etc...) to make custom ones.
The hard part about the CB is that it's a banjo fitting on the master cylinder side and then a compression fitting where it bolts to the hardline on the frame. This eliminates most pre-made lines out there.
08-05-2015, 10:46 AM
veech_imp Offline
Threads: 3
I would check japan.webike.net. They have a ton of brake lines under the CB1100 section.
08-05-2015, 10:50 AM
Pterodactyl_imp Offline
Threads: 75
Bob, I can't help you with a specific supplier but if you Google up "Motorcycle brake lines USA" you will be faced with a world of choice, both standard and custom.
Good luck and Cheers,
Inhouse Bob Offline
Threads: 34
Likes Given: 15
(08-05-2015, 10:50 AM)veech_imp Wrote: I would check japan.webike.net. They have a ton of brake lines under the CB1100 section.
That's the trouble I'm having. So many choices and I am pretty clueless as to what I really need. No site seems to list "2013 CB1100ABS front brake lines - 3" longer than stock so Bob can use his bar risers."
Now wouldn't that be so very helpful? Celebrate
08-05-2015, 12:03 PM
Threads: 75
OK Bob, why don't you remove your brake lines, send them to a custom fabricator (use good ol' Google) and ask for a set 3ins longer. You can get some real nice colours as well. Send us a pic.
08-05-2015, 12:27 PM
Redbird_imp Offline
Threads: 7
kmoney has a good suggestion. Find a local company that makes up lines. Ask a farm implement dealer about one, or someplace that sell fork lifts, etc. Then take a ride there and show them what you have now and ask if they can make one 3 inches longer. My bet is that they can.
08-06-2015, 01:26 AM
redbirds_imp Offline
Threads: 186
Try this.
http://www.galferusa.com/motorcycle-brake-lines/
08-06-2015, 01:32 AM
Inhouse Bob Offline
Threads: 34
Likes Given: 15
Thanks all! I found Crossroads Cycles in Arlington, VA. Dennis, the owner, was very helpful and is getting me fixed up.
Onward and upward!
Bob
08-06-2015, 03:16 AM
EarsOnWheels_imp Offline
Threads: 13
Great! Are they ordering/installing for you? I'd be itching to give it a try when you are set up. Would be great to get a more upright position.
08-06-2015, 04:09 AM
  longer length rear brake pedal darmahman_imp 3 426 06-11-2022, 07:12 AM
  Don Guhl No Longer Tuning Motorcycle ECUs tj_gee_imp 45 3,116 03-08-2022, 02:48 AM
  ROX Risers and longer brake line? MrBob_imp 3 467 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Help me find parts to mount highway pegs please LikeAfox_imp 23 1,778 05-24-2021, 10:03 PM
Last Post: LikeAfox_imp
  A question about shorter cables,brake lines. FLYTYM_imp 3 453 03-30-2021, 01:41 AM
Last Post: sonnyb_imp
  Where to find Brake Lines (ABS model) ? mrbi0_imp 5 508 05-15-2017, 05:48 PM
  Braided Brake Lines beardyweirdy@me.com_imp 5 527 05-14-2017, 07:02 PM
Last Post: mrbi0_imp
  Longer shifter peg? Ghis_imp 11 848 02-03-2017, 04:10 AM
  CB1100 modified cowhide handmade cushion Lingge lines jp4141432_imp 4 473 09-27-2016, 11:38 PM
Last Post: 4 Paws_imp
  Longer footpegs? ryanschillinger_imp 6 545 09-17-2016, 02:29 AM
Last Post: ryanschillinger_imp
