Swapping tanks
2014ltdltz Offline
Threads: 11
Swapping tanks
Anyone have a comprehensive thread on swapping a 2013-2014 tank to a 2017 tank? If so, parts list with part #s needed to do the job properly? Thanks.
05-03-2022, 07:56 AM
Likes Given: 1,016
RE: Swapping tanks
It’s been done. I can’t remember a comprehensive thread, but chync has done it, http://cb1100forum.com/forum/showthread.php?tid=11505; jimbo has done it http://cb1100forum.com/forum/showthread.php?tid=16914.
You could contact either or both of them. The year of your bike might matter. The fuel pump was different on the 2013 model. See http://cb1100forum.com/forum/showthread....#pid233754
05-03-2022, 08:26 AM
2014ltdltz Offline
Threads: 11
RE: Swapping tanks
Thanks for the info...now to find the parts to do the swap. Unfortunately, I am still far short of the required #25 threads to put in a WTB ad.....
05-05-2022, 12:58 PM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Given: 483
RE: Swapping tanks
(05-05-2022, 12:58 PM)2014ltdltz_imp Wrote: Thanks for the info...now to find the parts to do the swap. Unfortunately, I am still far short of the required #25 threads to put in a WTB ad.....
Look for the "View Today's Posts" link in the upper right hand part of the page and click on it. You will be surprised at how many things you can make a comment on. You will get there before you know it. I am sure many will see these posts and want to help, if they can, too. Good luck. Keep us posted.
Thumbs Up
05-05-2022, 11:29 PM
12milesout Offline
Threads: 4
RE: Swapping tanks
I swapped a 2017 tank (purchased from forum member pekingduck) onto my 2014 std, and IIRC, all I needed was a different fuel cap. He may have swapped out the fuel pump, though. I went with a keyless fuel cap so I didn’t have to mess with a second key, or getting it keyed to match the ignition.
05-06-2022, 03:13 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Swapping tanks
The 2017 cap uses a completely different style of key from earlier models, and there is no way of cutting keys to match or changing the locks. I have to carry two keys, unfortunately.
05-06-2022, 04:07 AM
ymtnpoah11_imp Offline
Threads: 9
RE: Swapping tanks
Replying to say, "Heard. Same boat." (And now this counts as one more!)
Cheers!
07-22-2022, 04:10 AM
  Are the new tanks interchangeable with the old ones? The_Last_of_Ben_imp 9 886 05-23-2018, 10:15 AM
Last Post: Roper_imp
  Whitehouse 4.7 Gallon Tanks ??? JF Coastal_imp 8 786 05-27-2015, 08:56 AM
Last Post: kennyw
  Samurider used fuel tanks brougham79_imp 14 755 09-04-2014, 05:02 AM
Last Post: Randy B
  Used gas tanks on Samurider (heads up fans of black) Guth_imp 7 454 10-26-2013, 01:44 PM
Last Post: rboe
  Different colors ....black, silver, white OEM tanks RajunCajun_imp 1 211 06-28-2013, 06:46 AM
Last Post: Ack-CB11_imp
