Are the new tanks interchangeable with the old ones?
The_Last_of_Ben_imp Offline
Threads: 2
Like if I buy a 2017 EX tank from Samurider like this one https://www.samurider.com/?p=26001/#itemImage will it fit on my 2013 CB1100?
05-23-2018, 03:27 AM
Retsel_imp Offline
Threads: 24
I believe so, I think a couple of people have done it, but check with Takashi through the quote link on the website.
05-23-2018, 03:30 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Are the new tanks interchangeable with the old ones?
It will fit as Retsel said. A few HAVE done it already. Just be aware that the fuel gauge reading will not be correct. Close, but not as good as you are used to now.
05-23-2018, 04:52 AM
Threads: 2
(05-23-2018, 04:52 AM)Lord Popgun_imp Wrote: It will fit as Retsel said. A few HAVE done it already. Just be aware that the fuel gauge reading will not be correct. Close, but not as good as you are used to now.
I gotcha. Do you think it would read over or under the actual fuel content? Also I thought I read on here about a way to recalibrate the fuel gauge awhile ago. Do you know anything about that?
05-23-2018, 05:37 AM
Lord Popgun Offline
Virginia
Likes Given: 136
I think it read low when it wasn’t. The only way to recalibrate is to bend the float arm. I’ll have to search around to find the thread.
Check out this post and the one following: http://cb1100forum.com/forum/showthread....#pid202753
And this one by me: http://cb1100forum.com/forum/showthread....#pid173492 There is another hose you have to add to and route down to under the bike. Just read post 16 about that hose.
You can search on 2017 tank, select posts (instead of threads) and a lot of posts come up. I’m not reading them all. Smile
05-23-2018, 05:48 AM
Threads: 2
Thanks a lot popgun! Looks like it fits right on there.
05-23-2018, 07:28 AM
Threads: 346
Likes Given: 964
You're a good man, popgun. Beer
05-23-2018, 07:31 AM
Lord Popgun Offline
Virginia
Likes Given: 136
Thanks Cormanus! We all try.
Ben, if you didn’t, look at the bike in the first post of the thread: http://cb1100forum.com/forum/showthread....#pid183626
Its a ‘14, but the ‘13 and ‘14 tanks fit each other. Pretty much all the models do. Maybe the dlx is tad different. I think it fits, just tight against the seat, but I’d have to search again.
05-23-2018, 08:21 AM
peterbaron Offline
Likes Received: 575 in 312 posts
Likes Given: 958
(05-23-2018, 08:21 AM)Lord Popgun_imp Wrote: Thanks Cormanus! We all try.
"13 and "14 tank models are swappable for sure = I did mine (Canadian)
You only have to transfer fuel pump assy (both have an oval shape housing), cuz '13 has a flat 3 pin connector versus '14 - 4 pin square. Fuel reading are fine, and bottom/reserve = perfect
As many other and Popgun mentioned, Takashi will have a final say about yellow tank.
Good luck, nice colour chosenClap
pb
05-23-2018, 08:56 AM
Roper_imp Offline
Threads: 32
I can certainly understand wanting a larger fuel capacity and a cool seamless tank. if it's the color you're after, get the stock tank painted. Then you get to keep the cool wing badge and the ability to use a magnetic tank bag Smile
05-23-2018, 10:15 AM
  Swapping tanks 2014ltdltz 6 533 07-22-2022, 04:10 AM
Last Post: ymtnpoah11_imp
  Whitehouse 4.7 Gallon Tanks ??? JF Coastal_imp 8 753 05-27-2015, 08:56 AM
Last Post: kennyw
  Side Panels Interchangeable? 2013/2014 Mashup Stichill_imp 6 505 04-20-2015, 07:18 AM
Last Post: Elipten_imp
  Samurider used fuel tanks brougham79_imp 14 735 09-04-2014, 05:02 AM
Last Post: Randy B
  Used gas tanks on Samurider (heads up fans of black) Guth_imp 7 442 10-26-2013, 01:44 PM
Last Post: rboe
  Different colors ....black, silver, white OEM tanks RajunCajun_imp 1 200 06-28-2013, 06:46 AM
Last Post: Ack-CB11_imp
