Threads: 18
Hello all! Planning on removing the front forks for service and a posible powdercoat but don't quite know what is available out there as far as front stands go... I noticed there are two reference points under the oil pan, are they Jack Points to raise the front of our bikes? just curious to what you fellas have done.....
Thanks!
Threads: 46
I got an email from George Hoffman from Pitbull last week:
"Okay, if you're using our new Hybrid Front Stand I think the #19 pin would be the place to start. I'm at home right now but if you can make sure I'm in the loop when you order, I'll find at least one more pin that might be a good match. IF you do have issues with that pin, please take a photo so we can see what you see and we can sort it out for you. Thanks and have a great day!"
http://www.pit-bull.com/motorcycle-stands.shtml
I just havn't got back to him yet.
Without a stand you can either jack it up or hang it by the bars.
Likes Received: 200 in 118 posts
Likes Given: 142
So Ack, what do you think those points sticking down under the front of the engine are?
Threads: 46
(08-06-2013, 03:35 AM)Lord Popgun_imp Wrote: So Ack, what do you think those points sticking down under the front of the engine are?
I don't know, I know one protects the drain plug. I hung mine from the bars. A member already did his wheels and put his on an ammo can, so they must be strong enough?
It happened I already had a Pitbull stand I'd bought for a Yamaha FZR400. It fit my FZ8 and the pin also fit the CB1100. Didn't even have to remove the horns. The steering stem is taper so the pin does not go all the way in but goes in plenty far enough. No problems at all.
That's awesome, Thanks for the info. I was worried about the horns too..........
What # pin was it?
Threads: 18
thanks for the tips and replies. Oh Okay I do have a front stand from my Street triple that I got from SVracing.com which lifts it from underneath the triple trees but when I checked the hole on the CB1100 it was just too big but will see what pins I have and will let you know what fits.... Thanks Again!
Threads: 5
If you were on the center stand and took off the front wheel, would removing the weight let it rock back on the rear tire.? Even if it doesn't, you just need to strap the rear down to a couple of 5gal buckets filled with water and you don't need a front stand unless you're taking both wheels off at the same time.
Likes Given: 142
If you guys use one of those front fork stands, could you post a pic of how they work? I don't have a clue...
I did look at the pics in the first post link, but is there really room to remove the wheel, etc., when using a stand like that?
Sorry if I sound dumb...
Threads: 46
[quote='popgun' pid='10301' dateline='1375876383']
It is hard to tell what goes on under there.
http://www.youtube.com/watch?v=aUatsXvaKhY
They also make one that lifts on the fork bottoms for just wheel removel, you can you that one solo on the front.
Likes Given: 142
Threads: 29
(08-06-2013, 09:53 PM)Lord Popgun_imp Wrote: If you guys use one of those front fork stands, could you post a pic of how they work? I don't have a clue...
There are no dumb questions. Just stuff we haven't learned yet. I don't know how they work either as I've never seen one. I have learned more about this bike here than I could have picked up in 50 years on my own. So yeah, photos please.
Chip
