Lubricating Chain Without Center Stand?
This question is not really about our CB (unless you've removed the center stand on yours).... Any tips on how to make chain cleaning/lubing easier on a bike with no center stand?
1. Buy a centerstand so you can rotate the rear wheel
2. Buy a paddock stand so you can rotate the rear wheel
3. Push the bike forward and back so you can rotate the rear wheel
4. Neglect it
My Ducati doesn't have a centerstand and it's unlikely I'll spend the money to buy a paddock stand for it. Fortunately, the bike is easy to push around (375 lbs.), but cleaning and lubing the chain that way is a pain.
I used to own a few bikes without center stands (and didn't like it much). This was back before the sealed o-ring chains, when chains required a lot more maintenance than they do today.
If the bike was in the garage, I had a lightweight floor jack that I could use to raise the back of the bike. For lubing on the road, there wasn't much choice but to roll, spray, roll, spray...
Hmmm..maybe a jack would be the solution. I wonder if I could use a scissor jack from one of my cars
(07-29-2017, 12:16 PM)EmptySea_imp Wrote: Hmmm..maybe a jack would be the solution. I wonder if I could use a scissor jack from one of my cars
Might work with a piece of 2x4 under the center of the swingarm, but you'd need a way to stabilize the front end I would think.
Good point..
Use the bottom part of an aluminum crutch. The part with the clicker on it?
I put Velcro or a cat collar real tight on the front brake lever. Pull the bike over on it's side stand just a little bit then use what's left of the crutch to jack the bike up. Adjust clicker as needed. Either on a peg or the swing arm or the axle nut.
It works great
sounds great, but wouldn't a jack do the same thing? maybe i'm missing something
Hmmm, not sure, but you're making me value the awesomeness of the center stand even more than I already did.
Without a centerstand, if you have a friend, one person leans the bike on the center stand while another spins the rear wheel and lubes the chain..
If you have access to car jacks, mount some rear spools (cheap) and you can put the bike on the car jacks on the spools (usually best with a friend), using the method above by leaning it on the side side and pop on side on then the other. With practice you can do it your self.. You can also use a milk crate too if it won't hit the exhaust (but milk crates will break after a bit)
https://www.revzilla.com/blog_content_im...hange1.jpg
Another option is to look for an off road alternate side stand. In off roading you get flats.. I carry a home made stand for the other side. I have a stand with multiple holes and a cottor pin for adjustable lengths and it has a sturdy foot.. I lean the bike on the side stand and put the the stand under the bike so it sits up right so I can take either wheel off to patch it.. I carry it in my tail bag.. I can take a pic of you want
Scroll down a bit on this link to see the bike with the rear off
http://www.dualsportbc.com/forums/showth...ire-levers
  Center stand and new chain / sprockets jermo47_imp 8 882 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 494 05-22-2023, 12:25 PM
  ... the perfect side-stand support ? j3gq_imp 17 1,249 07-14-2022, 08:36 AM
  Fuel gauge flashing from center outward.... mattmcuomo@yahoo.com 29 2,338 06-02-2022, 03:13 AM
Last Post: thomas_imp
  center stand cj599_imp 12 918 04-17-2021, 03:03 AM
Last Post: cj599_imp
  side stand too short? bioman_imp 44 3,515 10-13-2020, 07:40 AM
Last Post: Ninemeister_imp
   Centre Stand 2-Parter eddi0_imp 12 877 07-29-2020, 09:36 AM
  Center Stand Doesn't Always Retract Fully emptysea 4 341 01-03-2020, 04:47 AM
Last Post: LongRanger_imp
  Pitbull Hybrid Front Fork Stand 2017EX_imp 3 344 08-26-2019, 04:49 AM
Last Post: Rocky_imp
  Lubricating switches... Bazbro_imp 15 1,075 06-22-2019, 12:32 AM
Last Post: Bazbro_imp
