odd knocking sound
hey friends,
So i was away from my bike for a week. the tank was close to empty and when i was riding it yesterday i noticed a knocking sound coming from my front wheel area.
After inspecting, everything seemed tight, though when am riding the bike at a slow speed i can hear this and am a bit concerned.
its probably a bolt not completely tightened (have to check that this afternoon)
not sure if you all have any suggestions.
figured, id toss this out there.
thanks in advance!
(10-24-2013, 11:25 PM)silascopathic_imp Wrote: hey friends,
thanks in advance!
Does it sound like a rotation noise that increases and decreases with speed???
Could this be the full floating discs? A slight rattle at low speed is normal.
Google Motorcycle Floating Discs Rattle .
The who now? Our bikes have a conventional multi-plate wet clutch.
BTW, OP, are you sure it's not coming from the engine? Mine knocks pretty badly when hot/stressed. Not ignition knock, but metallic knock. I just assume this is the noise the engine makes when it's hot and am not worried about it.
I 2nd this. I think you hear more engine noise with the KSY full system since the Stock manifold/Exhaust has thicker walls that limits engine noise a bit. But check any loose bolts or parts just to make sure, Also if you have the time do a video so we could compare...
goodluck!
I feel like its the rotors, i only hear it when coming to a stop and at slower speeds. when the bike is cruising i do not hear it at all.
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,986 11-16-2025, 12:01 PM
Last Post: TheLegend
  2014 rear wheel knocking noise dunebuggy_imp 7 982 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Sound check what wrong tory_imp 3 438 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Best Honda CB1100 Exhaust Sound RS EX? charles2021_imp 1 276 05-27-2021, 09:47 AM
Last Post: bioman_imp
   Ticking / clicking sound after oil change simplest2remember_imp 12 994 02-03-2021, 01:32 AM
  Chain making clanking grinding sound. bflint 36 3,017 11-09-2020, 05:04 AM
Last Post: LakeWylieJoe_imp
  Ticking Pinging sound Maurice_imp 17 1,302 05-05-2020, 11:19 PM
Last Post: alprider
  Engine sound kklandzw_imp 3 432 11-17-2019, 04:01 PM
Last Post: zirconxi_imp
   Engine Sound Changed After Service EarsOnWheels_imp 19 1,214 07-28-2017, 11:07 AM
  'Whine' sound/problem ride4now_imp 17 1,302 10-10-2016, 09:43 AM
Last Post: ride4now_imp
