About your valve adjustment, plug replacement...
These are emissions-related maintenance intervals. It's entirely possible that the bike could go much longer but since the bike is air-cooled, the maintenance schedule is much tighter in order to meet EPA requirements.
So there is some truth in the notion that 8K is an absurdly short interval, especially for spark plugs.
How many have found valves out of adjustment on the first 8K service?
Not me. In fact, with the exception of one intake valve, all mine were exactly on spec. The one intake was still within the +/- tolerance and didn't need to be adjusted.
Is it cheapness or sloth that inclines you to neglect your baby?
Me, I'd prefer to check the valves every 8000 miles and keep the clearances as close as possible to centered on the spec. Better for the bike's long-term health, better for performance, and the injectors practically synchronize themselves when you've got all the valves as close as possible to uniform clearance.
If you are resourceful & patient (& neurotic), you can even find the half-size shims (I believe they go to .025mm increments instead of the usual .05mm) to help keep the clearances center-mass.
(03-26-2014, 03:53 AM)calamarichris_imp Wrote: Is it cheapness or sloth that inclines you to neglect your baby?
And I'll bet your sock drawer is color coded for the day of the week. Man, life is too short to be that picky.
What's a "sock"? I don't even wash my feet, but your bike is your baby, man!
It is best to run your valve clearances to the loose side. Valves run cooler that way.
ROFL
And I'll bet your sock drawer is color coded for the day of the week. Man, life is too short to be that picky. ROFL
(03-27-2014, 03:00 AM)calamarichris_imp Wrote: What's a "sock"? I don't even wash my feet, but your bike is your baby, man!
Do you even own a CB1100? Have you even ridden one?
I do and have, so maybe you're just an Internet blowhard, trying to push a few buttons?
I think we're all on to you. Enjoy your W800. Hello
  NGK spark plug options Jonnyteabag_imp 6 631 08-05-2026, 11:35 PM
Last Post: JRD
  Valve Adjustment Shims dave 13 689 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Booster Plug on an RS TheLegend 6 488 04-22-2026, 06:31 AM
Last Post: TheLegend
  Valve Adjustment and Camshaft Removal dave 5 624 03-21-2026, 04:49 PM
  CB1300 headlight bucket replacement spechg 5 379 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 988 01-19-2026, 05:09 AM
  Valve Adjustment dave 6 858 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 926 07-26-2025, 11:27 AM
Last Post: bflint
  Rear brake pad replacement LongRanger_imp 39 3,578 05-03-2025, 10:45 AM
Last Post: Delphisa
  Valve Adjustment Intervals CBRider_imp 32 2,841 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
