Check Torque on Exhaust Pipe
I disassembled my exhaust system last evening. Three of the eight nuts where a touch more than hand tight. Maybe its just mine but I would get out your torque wrench for a quick check. The torque value is 15 lbf-ft
Cip against forum rules to post copyrighted pics. Please delete but feel free to post the values if you type them out.
(05-06-2014, 10:58 PM)The ferret_imp Wrote: Cip against forum rules to post copyrighted pics. Please delete but feel free to post the values if you type them out.
Corrected Sir
Thank you sir. I made the same error on my "Recommended shift points" thread and had to delete my own photo of the manual. Also gave my self one warning point. At 3 points I am no longer qualified to be a moderator. lol
BTW some others found the same thing last year, loose header nuts.
I noticed the same with mine. Not too much longer and they would have fell off.
Might this not explain some of the unusual noises some have remarked on? Nothing like a loose exhaust system to make weird noises.
(05-07-2014, 01:53 AM)Red Mist_imp Wrote: Might this not explain some of the unusual noises some have remarked on? Nothing like a loose exhaust system to make weird noises.
A similar complaint of strange noises on the Triumph 1050 forum was traced to loose exhaust systems.
A couple of mine were loose when i pulled the headers. I think this issue may be fairly common from what I've seen on this forum.
They get loose sometimes on new stuff from the expanding & contracting of the parts.Once you snug them up for the first time they should be GTG..Kinda like on new mag wheels they tell you to check the lugnuts after the first 100 miles or so...Thumbs Up
I had two that were slightly loose. Thanks for making me check!
Photo First Check Engine Light Ever on a Bike doug1976 2 235 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 635 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,421 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 684 08-22-2024, 09:39 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 516 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Torque value question Jonnyteabag_imp 9 675 03-10-2023, 01:00 AM
Last Post: 1973cb750
  Sound check what wrong tory_imp 3 431 03-30-2022, 12:33 AM
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 655 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Pipe Master 4 into 4 Houtman_imp 127 9,190 07-24-2021, 06:39 AM
Last Post: michael1954
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 432 04-03-2021, 01:35 AM
