21,000 mile valve check
Just got done checking the valves at 21,000 miles. They were all exactly the same as they were at 8,000, pretty much right down the middle. The plugs looked like new as well. I think I'm going to push the valves and plugs out to once every 16,000 miles.
I'm in the process of checking valve clearances now, at 41500kms. Will report on results. Plugs look good.
I did a plug reading and valve check a month after I installed the Yoshi at 5000 and before my warranty was out. Everything was perfect.
  Valve Adjustment Shims dave 13 609 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 576 03-21-2026, 04:49 PM
Photo First Check Engine Light Ever on a Bike doug1976 2 205 01-14-2026, 06:47 PM
  Valve Adjustment dave 6 823 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 873 07-26-2025, 11:27 AM
Last Post: bflint
  Check your clips! Gone in 60 3 581 07-01-2025, 11:27 AM
  Valve Adjustment Intervals CBRider_imp 32 2,627 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Basic Maintenance: Daily Check rdprdp01 17 1,308 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 639 08-22-2024, 09:39 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,422 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
