Overflow goo .. Just a reminder to check yours
Tonight while looking my bike over I noticed some goo in the overflow hose on the bottom of the air box. Fix was easy. Slide the overflow hose off it's nipple, squeeze the cap clamp with some pliers and move it up the tube, pull the cap, dump any fluid onto a paper towel, roll up another paper towel and slide it up into the tube from both directions and spin it around a couple of times to clean up the hose, then put the cap back in, slide the clamp back on using the pliers, slip the hose back over the nipple and you are done.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020004_zpsc2eea6e9.jpg.html][Image: 3784a57cecaec9d15285f0d382722981.jpg]
Checked the other overflow hose under the bike and it was clean and empty.
Bike has just over 9000 miles on it.
Photo First Check Engine Light Ever on a Bike doug1976 2 209 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 588 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,327 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 649 08-22-2024, 09:39 AM
  Sound check what wrong tory_imp 3 400 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,762 01-13-2021, 12:36 PM
  Gas leaking from overflow tubes Edtheguy_imp 11 758 09-01-2020, 02:35 AM
  Oil level difference between check zirconxi_imp 29 1,773 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  Fuel Tank overflow drain tube. zirconxi_imp 11 843 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  cam chain check max 0 174 04-22-2020, 08:26 AM
Last Post: max
