Lowering rear brake lever
Someone posted that they had trimmed the bottom of the adjusting rod to lower the brake lever. How much was trimmed off and how much did that action lower the brake lever?
TIA
White Dog,
If you try it, a new push rod is only ~11 bucks.
http://www.partsfish.com/oemparts/a/hon/...cylinder-1
A better place to look for pricing on parts:
Hondabikes.com
just sayin'
(04-18-2015, 03:54 AM)Olyrider_imp Wrote: A better place to look for pricing on parts:
Hondabikes.com
just sayin'
I added that to my favorites Oly. Didn't know about that one. Thumbs Up
In the case of the plunger, you would save about 40 cents. Tongue
I decided to grind a bit of material from the top of the pedal that contacts the adjusting screw. If the screw is shortened, it might eliminate any possible return to a higher position afterwards. I removed the foot peg assembly & the brake pedal. Ground about .100" from the contact point & reinstalled loosely to confirm that the adjuster would extend to its maximum without contact the pedal. Reinstalled everything & will live with it.
I considered altering the pedal by cutting or bending, but couldn't bring myself to something that would require refinishing the pedal after welding or heating. Just my opinion. Rocket
I sprayed my lever with chrome paint. I may re-spray it black or have it powder-coated. I can always have it bent back. My man made his living working metal and he bent my lever by hand after heating.
  Rear brake pad replacement LongRanger_imp 39 3,336 05-03-2025, 10:45 AM
Last Post: Delphisa
  Replace clutch Lever Davidjill_imp 10 908 02-06-2025, 01:27 AM
  Rear Brake Pedal Adjustment Gone in 60 12 1,024 04-04-2024, 08:18 AM
  Front brake lever ROCK hard ichiban_imp 37 3,422 02-10-2023, 10:54 PM
  Long shift lever Sam Mac_imp 1 249 02-08-2023, 08:30 AM
  Lowering the back Griz53_imp 4 417 01-23-2023, 06:52 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,422 10-28-2022, 09:27 PM
   Rear brake pedal Mixagon_imp 28 1,924 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 426 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  rear brake question Crossfire_imp 12 803 02-18-2022, 03:02 AM
Last Post: bvictory_imp
