Surging at Idle
I have a 2014 standard with about 4k miles on it and have noticed it will occasionally surge when sitting at idle. I haven't noticed it being specific to a hot or cold engine, it will just randomly happen. Yesterday traffic was heavy and while I was idling at slow speed with the clutch in it was surging. Traffic cleared and I was able to get back up to speed. I came up to a stoplight 10 mins later and it idled fine. That's a typical example. It's not really too annoying but I was curious if anyone else has noticed this or if it's a sign of something needing tuning.
There is a fair amount of discussion on this. Search around and you'll find it. Smile
You might want to do the TPS trick first. Cost nothing and is easy. Here is how--first post: http://cb1100forum.com/forum/showthread.php?tid=4028
This sounds different. I've always experienced the slight roughness while riding slowly in first gear below 2K rpm, but mine has always had a rock steady idle.
Yes, I found lots of discussion on the roughness below 2k rpm, but this is while sitting at idle with no throttle applied. It seems like it's not a common thing judging by the lack of replies, but it's also so rare and not really worth it for me to look into unless it gets worse.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,741 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,125 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 418 09-15-2024, 12:16 AM
  another idle thread Tom_imp 11 990 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,637 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,206 09-06-2023, 01:36 AM
  High idle mattmcuomo@yahoo.com 7 684 10-29-2022, 11:09 AM
  Fast Idle Problem Solved Nachodaddy 17 1,492 10-08-2022, 09:18 AM
   Dutch's High idle thread DutchRutter 17 1,544 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another High Idle Problem emptysea 60 4,020 07-05-2022, 11:41 AM
