wheel balance weights
On my rear wheel there are 8 weights right at the yellow circle on the tire and the yellow dot on the rim. The tire mark is mounted on the opposite side from the valve. That seems excessive but I'm not racing so I guess its ok, but I would feel better if they would have put half of them on each side of the rim.
My front has 4--2 on each side. The rear has 2--both on one side
CA200 is the tire man. He can most likely talk about motorcycle tire balancing in much greater detail than we can stand!
OK I will try to make this as short so as not to put you all to sleep.
All street rim/tires need to be balanced if you go highway speeds.
As most of you might have noticed there is a painted dot on the side of your wheel rim. ( Only Honda does this and it does wear off after time).
Honda balances their rims. All other Mfg. consider where the valve
stem is should be the so called "heavy " spot on the rim. This is not always the case. Most , but not all tire Mfg. put a dot on the sidewall of a tire to
mark the " light" side of the tire. Michelin and Avon do not. They claim they are better then the rest. I have found that not to be true.
When you mount a tire you should mount the dot on the tire to where
the valve stem is so when you balance it will take the least weight.
Some times ( about 10%) if the tire needs a lot of weight you can dismount it and turn it 180 degrees to try to see if it will take less weight.
How much is to much. 80-100 grams is what we always considered to much
and I would return the tire. Even after mounting 1000s of tires I can not
remember a radial asking for that much.
I had the most problems with American tires mounted on American bikes.
The wide white walls were the worst.
I did believe in having the best balancer money could buy because we
did so many tires. I have looked at some of the " beads and balance
liquids and they really don't make any sense to me.
Making tires/wheels lighter makes a big difference the way a bike turns in etc..
Hope this makes sense, if not don't be afraid to ask me.
Thanks. I don't know how many grams but there are 8 segments at the dots on one side of the rim. I'm confident that must be ok because I don't think the Honda factory would pass through anything out of spec.
That's maybe 40 grams , the guy was just lazy putting all the weight on one side.
You can balance one side of rim to the other but it has to be more then 4 1/2" wide.
Mine has 10 grams on the front and none on the rear.
not sure why these havnt caught on DYNA BEADS, no ugly mess either. When I get my tires done Im going to tell them this is what I want:
http://www.innovativebalancing.com/motorcycle.htm
I may be old school but I always refused to put in Daya beads when customers asked. I did dismount tires with them.
Ya you try and take them out when you take it off!
Some people really think they work. I did talk to them when they showed up at the dealer show but I was not convinced.
I did check a tire that had them in on my balancer and it was off just as much as normal.
Say...did anyone else's bike not come with any weights on the rims??
After 9,000 wobble-free miles, I can't say it's been a problem.
I'll have to double check but, I'm pretty sure mine came without weights as well. Is that something the dealer does when they prep or do they come balanced from the factory?
(03-17-2016, 11:44 PM)ecka00_imp Wrote: I'll have to double check but, I'm pretty sure mine came without weights as well. Is that something the dealer does when they prep or do they come balanced from the factory?
Spin balancing and wheel weights would be applied from the factory. Our wheels and tires have factory paint marking heaviest point on the rim and lightest point on the tire and I remember mine came with the dots properly aligned and minimal wheel weights -- so the factory actually did put effort into doing it right.
  Front wheel bearing noise? MagnaRider 20 1,910 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 374 02-05-2026, 08:11 AM
Last Post: 1973cb750
  Injectors syncro/balance TheLegend 15 2,179 11-10-2025, 02:07 AM
Last Post: TheLegend
  CB11OO EX wheel rims sprint 6 690 02-26-2025, 06:16 AM
  Wheel sensors The Gecko_imp 48 4,082 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  2013 replacement wheel Randy B 8 825 11-13-2022, 10:32 AM
Last Post: Randy B
  wheel imbalance j3gq_imp 7 696 07-03-2022, 09:35 AM
  Kink in rear (spoked) wheel Ayrshire Dunx_imp 1 274 04-09-2022, 09:37 PM
  Friction front wheel j3gq_imp 12 986 12-12-2021, 01:26 PM
Last Post: jimgl3_imp
  Tires yet again - spoked wheel options Rogerdj_imp 12 1,002 09-05-2021, 04:56 PM
Last Post: Henrik_imp
