Idle problem resolved
Last weekend took off for a trip to Orlando to visit with my son. I take all the back roads north of Tampa to get there. The bike ran great. On the way back home I was heading through Clermont. I noticed the bike was acting up with low rpm of about 500. I just chalked it up to a bit of heavy traffic. Decided to pull over for a fill up & after I cranked back up, it shot to 2000 then after taking off, it went back to 1500. I'm sure this sounds familiar as I've seen a few threads on this. When I got home, got on the forum for info & did all my resets. But none of them helped. It was still on 1500 rpm.
Drove it for a day, even re-filled with fresh gas to no avail. Went ahead & scheduled appt. for Honda dealer. Took it in this morning. They did a total check, vacuum leaks, etc... Guess what my problem was? Zip ties on my throttle cable. I couldn't believe it because ties had been there for months. BUT...I adjusted the handle bars a couple days before heading over to Orlando & evidently tightened those ties a bit. Enough that when I hit a few bumps on my way back it tightened those cables too much causing the high idle. Once they cut off those zip ties, it was back to normal. Weird thing about it is, problem didn't occur for about 100 miles.
So check your zip ties guys when adjusting your bars.Biker
Thank you 68. I cut off the zip ties when I put on bar risers. Now I know not to put any back on.
I understand how a zip-tie could cause your RPM to increase, but how can it cause it to decrease to 500 RPM, as you described? My bike experienced the low (about 500) RPM condition before stalling on three different occasions now. Mysteriously the problem has corrected itself after storing it over night and riding it the next day. Haven't experienced the condition in almost two months now.
(05-21-2016, 03:03 AM)Dave_imp Wrote: I understand how a zip-tie could cause your RPM to increase, but how can it cause it to decrease to 500 RPM, as you described? My bike experienced the low (about 500) RPM condition before stalling on three different occasions now. Mysteriously the problem has corrected itself after storing it over night and riding it the next day. Haven't experienced the condition in almost two months now.
Yeah not sure about that 500 either. Prob. different issue that just happened at same time. But do know the zip ties were cause of 1500. It's running great now.
(05-20-2016, 10:43 AM)Roper_imp Wrote: Thank you 68. I cut off the zip ties when I put on bar risers. Now I know not to put any back on.
Yeah, I have riser as well that probably contributed to issue. Live & learn.
My guess would be that the throttle isn't closed all the way, the ECM gets erroneous readings from the sensors and commands the IACV to close too much. Just a SWAG. Maybe a dumb one Smile
(05-21-2016, 11:17 AM)Lord Popgun_imp Wrote: My guess would be that the throttle isn't closed all the way, the ECM gets erroneous readings from the sensors and commands the IACV to close too much. Just a SWAG. Maybe a dumb one Smile
Sounds good to me.
rearranged the 2 throttle cables a bit, but that did not resolve my persisting low idle to stall issue
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,509 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,113 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 418 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,245 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 984 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 646 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,607 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,194 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,760 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 850 01-20-2023, 04:53 PM
Last Post: max
