Out of gas - Beware estimated miles remaining!
I only had some short trips to do around the DC, so I didn't stop to fill up the tank yesterday when the initial Estimated Miles Remaining came on. Still had 30+ miles left today, so I took the "long" way home and stopped to eat dinner in Crystal City. After dinner, the bike wouldn't start! Battery was still good, and the starter sounded good. I suspected the fuel because the estimated miles left had changed several times between yesterday and today. I tried rocking/tilting the bike to get fuel where it needed to be, but no luck.
I walked to the nearest gas station, got a container and a gallon of gas, and returned to successfully start the bike.
[Image: 4435e28f4c192126036dcbf9d6510063.jpg]
Big thank you to the attendant at the gas station at Rt. 1 and 23rd. He gave me a free gallon of gas *and* showed me how to open the surprisingly complex container.
[Image: 1226f42baa8da8e7f1fb3d30ce1da35f.jpg]
Here is how many miles I'd gone:
[Image: bee174fa890725dc247160f224e5e309.jpg]
Lesson: even if the bike says you have 30 or 40 miles left, you may not have that much. I suspect it becomes less accurate the more you are stopping/starting the bike and doing little runs around town. It is probably most accurate when it first comes on, so if it says 40 miles to go, and *still* says 30 miles to go after you've gone much more than 10, be suspicious!
Bummer. Glad the guy helped you out! Keep in mind that if you ever need a rescue or gas or whatever, I have no life and will be glad to assist.
(12-20-2015, 01:16 PM)Inhouse Bob_imp Wrote: Bummer. Glad the guy helped you out! Keep in mind that if you ever need a rescue or gas or whatever, I have no life and will be glad to assist.
Thank you! Hopefully will be able to avoid running out of gas too often (eyeroll), but I'll be sure to put up the Bob Signal when trouble strikes!
How the estimated miles remaining (EMR) is calculated will be the key. Is it a simple arithmetic average of fuel consumption since the last refuel? Is it a sliding weighted average? Is it the average fuel consumption since day one? Can it be reset? I don't know the answer to these questions so I can only surmise that it is total average fuel consumption or average fuel consumption since last reset, neither being weighted. However any will give you a misleading result if riding conditions change quickly and you are nearing the end of the tank. For instance, out of the city I expect a tank ('10 model) to give me between 230 and 250kms. In the city I can get as little as 160kms to the tank; stopping, accelerating up to second and then stopping again really gulps the juice.
So if you are doing some "easy riding" the EMR might be, using your example, 30 miles. If you continue on your easy ride then that would be a reasonably accurate estimate. However if you enter heavy stop/start traffic conditions, or if you jack the RPMs up to 5-6000 to do a little knee down work, it will be inaccurate and you may have as little as, say, 15 miles remaining in the tank. Any averaging method, simple or even weighted, cannot "catch up" in the short time that remains. An averaging method must be used as a simple EMR calculated on the instantaneous fuel consumption would mean a wildly fluctuating EMR based on the current throttle position. Totally useless.
The solution? Just get to know the bike a bit better is the only answer I can give. Those of you that actually own one of them new fangled digital CBs may be able to come up with a better explanation, or even solution, to EarsonWheels' vexations.
You went 172.7 miles on a standard tank? That's actually pretty good mileage. If I'm doing mostly city riding, my '13s gauge starts flashing at around 115 miles. From experience, I know that I have almost a gallon remaining, so I usually try and hit a gas station within 25- 30 miles of that.
If the '14's computer uses the fuel gauge to estimate remaining fuel, it would probably be optimistic when initially starting the bike. I've noticed that the tank float reads considerably higher when the bike is on the sidestand. For example, yesterday my gauge started flashing the last bar just as I rolled into the driveway. This morning I started the bike as it was sitting on the sidestand and it was showing two bars. It wasn't until I'd ridden a few blocks that the gauge went back to the single flashing bar.
We have found on the ST 1300 board (the ST also has a fuel computer with countdown to empty) that the count down computer is fairly accurate as long as you don't turn the ignition off. Once the ignition is switched off it resets the computer. It doesn't remember exactly where you were in the countdown. Riding without shutting down I have taken both of my bikes down to the 12 miles to go before empty signal before getting gas.
Wisest thing to do IMO is learn how far you can go on a tank by using the trip meter, either A or B, which you set to zero when you fill up (in your case 172 miles) and make sure you get gas around the 150 mile mark. On mine I use the B trip meter and make sure I get gas around the 200 mile mark (I have gone as far as 225 miles)
haha cool, I just had the same question more or less in my topic Smile
I wont copy paste, but only the core question:
Judder gasrespons with 3.1 litres (0.8gallons) left (according to the display), is this normal and did I refuel a bit too early or did I refuel at the right moment I wonder Smile
Especially since the display also showed and estimated range of 59 km (thats 36 miles) depending on the riding style of the moment of course.
I can live with the fact it judders at 3.1 litres left in the tank, but not while saying I could ride about 59 km....
Thx!
(12-20-2015, 01:07 PM)EarsOnWheels_imp Wrote: I only had some short trips to do around the DC, so I didn't stop to fill up the tank yesterday when the initial Estimated Miles Remaining came on. Still had 30+ miles left today, so I took the "long" way home and stopped to eat dinner in Crystal City. After dinner, the bike wouldn't start! Battery was still good, and the starter sounded good. I suspected the fuel because the estimated miles left had changed several times between yesterday and today. I tried rocking/tilting the bike to get fuel where it needed to be, but no luck.
aside from the estimated distance, did you remember how many gallons the indicator showed?
That is 1 click after the estimated distance number..
this could be a indication for us users that its the time to do a refill Smile
And like I said above, I refilled when it had 59km left (36 miles) and the bike was already starting to judder, although long time user The Ferret said that our bikes dont judder at all no matter what the amount of gas is you have left in the tank.
And I agree that I wouldn't trust the remaining distance when you are riding in town or doing a lot of stop and go riding...
It should only be an indication, not an exact number you can trust upon.
However, I would trust the number of remaining fuel, I had 3.1 litres left and I refueled, that was after 303km of riding, thats 188miles.
Again, it would be helpful if you happen to know how many gallons you had in your tank...
(12-20-2015, 04:45 PM)Flynrider_imp Wrote: You went 172.7 miles on a standard tank? That's actually pretty good mileage. If I'm doing mostly city riding, my '13s gauge starts flashing at around 115 miles. From experience, I know that I have almost a gallon remaining, so I usually try and hit a gas station within 25- 30 miles of that.
wow, even on the old model, 172 has got to be bellow average...even if you do a lot of city riding.
You must be a spirited rider too in the city Smile
At least you should be able to get 125 miles when riding in the city on a 16liter tank, when riding normal, not even economical...
(12-20-2015, 10:01 PM)The ferret_imp Wrote: We have found on the ST 1300 board (the ST also has a fuel computer with countdown to empty) that the count down computer is fairly accurate as long as you don't turn the ignition off. Once the ignition is switched off it resets the computer. It doesn't remember exactly where you were in the countdown. Riding without shutting down I have taken both of my bikes down to the 12 miles to go before empty signal before getting gas.
Indeed, 200 miles should be easily achieved on the DXL/EX models.
Certainly when I know what I could reach with my Burgman 650s 15liter tank.
And when riding economical 225 miles should also be achievable.
I'll try to post a picture next time of the tripmeter B (I always reset this one between refills) reading 225 miles (or 362 km in my example) Smile
Quote:And like I said above, I refilled when it had 59km left (36 miles) and the bike was already starting to judder, although long time user The Ferret said that our bikes dont judder at all no matter what the amount of gas is you have left in the tank.
Oh, the bike DEFINITELY bucks like a Bronco when it's low on gas. Slowly at first, which means you have about 1-2 miles left, then it gets really bad, and then you're walking.
(12-21-2015, 02:59 AM)AzBob_imp Wrote: Quote:And like I said above, I refilled when it had 59km left (36 miles) and the bike was already starting to judder, although long time user The Ferret said that our bikes dont judder at all no matter what the amount of gas is you have left in the tank.
ROFL I have never experienced that (knock on wood) always filling up before that point.
aha thx for clarifying, The Ferret made me afraid Smile
(12-21-2015, 02:51 AM)The ferret_imp Wrote: nope, shouldn't judder. There is no interruption in fuel flow, it has fuel injection, not gravity fed. There is just a computer that tells you when you have .8 gallon left.
If it judders again (which I don't think it will) you will need to have it looked at by a Honda mechanic.
  Battery replacement - Beware aftermarket pekingduck 45 2,911 02-21-2020, 10:21 PM
  K&N Oil Filters BEWARE!!! davidsargee_imp 150 10,517 01-27-2020, 10:46 AM
  Low fuel indicator...Can't see miles remaining! glenridgerich_imp 14 1,116 10-02-2016, 12:37 AM
Last Post: BayAreaRick_imp
  No remaining fuel or range indication - big issue number 2 with this freakin bike Riko_imp 12 802 05-13-2016, 08:41 AM
Last Post: Riko_imp
  Oil Change 2700 miles CIP57_imp 48 3,582 08-15-2014, 10:41 PM
Last Post: Pterodactyl_imp
  Which oil at low miles Tortuga_imp 29 2,515 04-26-2014, 10:12 AM
Last Post: flynrider
  How many miles will CB last? HikerToo_imp 33 2,356 04-24-2014, 05:28 AM
Last Post: Tortuga_imp
  If you change your own plugs, beware! sanoke_imp 2 283 03-22-2014, 10:53 AM
