Tapping noise
I'm hearing a noise in the right side head of the engine, sounds like an out of adjustment valve, but the bike only has 3900 miles on it (2014). Most of the time it's when the engine is getting warm to operating temp, and can be heard throughout the rpm range, and louder under load. No loss of power or rough running. Could it from the crank gear out of adjustment, or did the valves come out of adjustment prematurely?
Thanks in advance.
Sent from my XT1254 using Tapatalk
(06-11-2016, 07:08 AM)BIGGREEK_imp Wrote: I'm hearing a noise in the right side head of the engine, sounds like an out of adjustment valve, but the bike only has 3900 miles on it (2014). Most of the time it's when the engine is getting warm to operating temp, and can be heard throughout the rpm range, and louder under load. No loss of power or rough running. Could it from the crank gear out of adjustment, or did the valves come out of adjustment prematurely?
Thanks in advance.
Crank balancer, they all do it, don't worry at all. Ride. Safely. It's fun.
  Front wheel bearing noise? MagnaRider 20 1,992 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,426 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 1,005 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 483 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 1,029 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 689 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 768 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 3,006 03-18-2021, 01:22 AM
  Strange wizzing noise LoyalKhan664_imp 28 2,338 10-02-2020, 05:58 AM
  Unhealthy Engine Knock / Noise spakins_imp 33 2,125 01-30-2020, 01:22 AM
Last Post: max
