Converting a 2013 CB1100 to cafe racer
Before I get in to it, I'm trying to figure out a few things, hope you guys with the knowledge can help a little, thanks in advance:
1. Can I remove the ABS from it?
If yes, is there a link with a how to?
Will the ECU complain about it?
2. Can I get the under seat triangle completely cleared?
I know it has the battery that I plan on moving under the rear hump.
Anything else there?
3. Air box, can it be opened and run clear?
I'm trying to get it as clean as possible.
4. Any other recommendations? Links? How-to would be greatly appreciated.
Thanks,
Ben
If you have an ABS model and you want to remove it then I wold suggest that you find someone that has a standard that might want an ABS model and do a deal for a swap. That would be your best bet IMHO.
There are a lot of guys that settled for a standard because they just couldn't find an ABS when they were looking.
Also I want to be sure that you actually have ABS. I only ask this because a lot of people have mistaken the rear reluctor wheel as an ABS sensor when it's primary function is as a speed sensor. If you have a reluctor on the front wheel along with extra brake hoses on the front calipers, then you have an ABS model. If you don't have those, you don't.
Good points and well put.
It is an ABS model.
I wouldn't mind swapping, but where would I find the right swap in my state etc.
Anyone wants to swap a 2013 CB1100 with ABS and 12K on it in south FL??
Hey InHouseBob - trip to Florida???
  CB1100 2013: what is the original chain relation? valkyrie_rider_imp 6 818 08-26-2024, 12:23 PM
Last Post: Randy B
  Oil change CB1100@2013: photos valkyrie_rider_imp 12 1,123 02-14-2024, 11:25 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 248 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 240 02-13-2024, 10:27 AM
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 497 05-22-2023, 12:25 PM
  Short shocks for 2013 CB1100 Griz53_imp 2 392 03-23-2023, 11:38 AM
Last Post: Griz53_imp
  2013 cb1100 Left Directional Light wont cancel. M3-SRT8_imp 15 1,173 08-01-2020, 07:16 PM
Last Post: max
  How to adjust the front forks on a 2013 CB1100 and a 2017 CB1100EX. michael1954 13 999 02-28-2020, 07:56 AM
  Easier Pull Clutch? 2013 CB1100 Jeeves_imp 10 809 02-18-2020, 12:38 PM
  CAFE RACER DIGEM_imp 3 304 04-03-2017, 01:40 AM
Last Post: missile_imp
